How can I make my AutoCAD 2014 Mac not to zoom out when I drag on View Cube everytime? For example, when you draw some 3D object and you want to change view angle only on particular object.
I found the way doing this: 1. Right click on "View Cube" > 2. "View Cube Settings" > 3. Uncheck "Zoom to extends".
P.S. And is there any way to change pivot point?
Solved by maxim_k. Go to Solution.
I use parallel view.
When I start 3DORBIT:
After 3DORBIT I loose object (need zoom out), so you can see blank workspace:
Pivot Point is somewhere in wrong place. But I really have no idea how AutoCAD works.
