AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Double-click to edit text in autocad lt for mac 2013
10 REPLIES 10
Message 1 of 11
mzarchs
844 Views, 10 Replies
I used to be able to double-click a dtext or mtext to edit it.  Same with text within a dimension string.  The last couple of days, that's no longer possible.  I can still use the tool set palette or go through the series of drop down menus to edit, but it's not nearly as convenient.  Has anyone else had the problem and found a way to resolve it?  Thanks.
10 REPLIES 10
Message 2 of 11
maxim_k
in reply to: mzarchs
What do you see at the Command prompt when you double-clock text object?
Are you able to open Block Editor when you double-click on block? (Or Edit Attribute window if the block contains attributes).
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 11
mzarchs
in reply to: maxim_k
Sorry about the delay, ...meetings.  When I double-click a text object, nothing appears in the command prompt line.  Similarly, nothing happens and nothing appears in the command prompt line when I double-click a block with editable attributes or any block.
Message 4 of 11
maxim_k
Does double-clicking works outside AutoCAD? For example in Finder (double-click on document - does it open associated application ?)
Have you tried to restart your Mac?
Anything was installed on your Mac recently?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 11
mzarchs
Yes, double-clicking works outside AutoCad.  And I have tried restarting the Mac.  Nothing new on the Mac for a long while now.  The double-click issue is only three days old now.
Message 6 of 11
maxim_k
Have you tried to reset AutoCAD options from Application tab of AutoCAD preferences?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 11
mzarchs
No, I haven't.  How much will that change?  Will I lose things like customized tool sets, etc.?  I was hoping for a more surgical fix, but that may be my only option.
Message 8 of 11
maxim_k
Yes, resetting will affect customization, so at first you can try just to trash AutoCAD preferences file. Look for it in ~/Library/Preferences folder (Library folder inside your Home folder) the name of .plist file should start with "com.autodesk"
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 11
mzarchs
I found the files:  com.autodesk.MCEFramework.plist.  So if I move it to the trash (or to the desktop?), will AutoCad generate a new one?  Is that the idea?  Thanks for all your help.
Message 10 of 11
maxim_k
Preferences file for AC 2013 for Mac name is:
com.autodesk.AutoCAD.R19.0.ACAD-B032.409.plist
seems you have found wrong file.
And yes, after you trash "com.autodesk.AutoCAD.R19.0.ACAD-B032.409.plist" file AutoCAD will create new one with default preferences (but your customization will be intact)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 11
mzarchs
Great, that worked!  It even seems to be responding more quickly now.  Thanks again for you help.
”Boost
