AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Disappeared "Edit Page Setup" Dialogue Box
32 REPLIES 32
Message 1 of 33
Sidragross
8650 Views, 32 Replies
I am unable to modify print prefferences due to the "Edit Page Setup" box failing to appear. The app runs as if the dialog is present (can't edit and menu bar is greyed out, but the box is nowhere to be found.
- Edit Page Set-up...: The print dialog shows up, but when I select the "Edit Page Setup..." button the app runs in a mode as if the box is there but it can't be seen. Hitting escape brings me back to the original print dialog box.
Things I've explored with no succes:
- checked all spaces
- hidden or closed all other windows
- permission repair
- tried on multiple dwg files
- Clean Screen mode
- hide all pallettes
- rebooting
-reinstalling Autocad
HELP!
Any thoughts?
Thank you in Advance,
Sidra
32 REPLIES 32
Message 21 of 33
maxim_k
in reply to: calaudiopile
Welcome to the Autodesk Forums!
Which AutoCAD do you have and which OS is running on your Mac?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 22 of 33
kecix3c
in reply to: Sidragross
hi, I couldnt find the file "com.autodesk......" please help
Message 23 of 33
maxim_k
It is inside ~/Library/Preferences folder - the Library folder is in your Home folder, not in the root of Mac HD, where you are looking for it now.
Library folder inside Home folder is hidden by default, to open it you need to select Go menu in Finder while you hold Option key - than it will appear in menu.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 24 of 33
wei503
in reply to: kecix3c
This is one of the Mavericks compatibility issues we fixed in AutoCAD 2013 for Mac SP2. Please click menu AutoCAD 2013 > check for updates to get the latest version. Thanks, Wei
Wei Ma
AutoCAD for Mac QA Manager
Message 25 of 33
shig01
So it sounds like I had a similar issue, and I suspect that it was because I had connected the laptop to a monitor which probably messed up the view window screen resolution
I recovered it by going into my System Preferences / Displays / and Scaled it to 1024 x 640, checked AutoCad if I could view the "Edit Page Setup" window, and then went back to System Preferences and switched the Display back to "Best for Display"
It seems to have worked for now...
Message 26 of 33
encola
in reply to: shig01
Shig01!
You are totally right!!! You are a genious!!
I was wondering why yesterday it worked and today not!!
And that's it: something to do with the retina display...of course!! If you use Airplay, probably that is the problem!
Solved for me!!
Message 27 of 33
encola
in reply to: shig01
ooooppsss.....
yesterday it worked! But today that method doesn't work......I don't know why. 😞
Any suggestion??
Message 28 of 33
maxim_k
It looks like Mavericks issue with AutoCAD 2013. Have you installed SP2 for AC 2013 for Mac? It should solve the problem.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 29 of 33
angelinaY
in reply to: maxim_k
Hi Maxim,
i have the same issue of disappearing Page Setup Dialogue Box; i couldnt find any if ur above mentioned file, but i have this under the same location.
com.autodesk.AutoCAD.R19.0.ACAD-B032.409.plist
Would it be working the same way if i trash this out?
Urgent respon is appreciated. (DEADLINEE is on a blink of time)
Thankyou.
Cheers,
Angie
Message 30 of 33
maxim_k
in reply to: angelinaY
Hi Angie,
All you need is to install all service packs for AutoCAD 2013.
You can use menu AutoCAD -> Check for updates
or download and install updates from here:
SP1 (just in case, because I think you already have it installed):
http://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2013-...
SP2:
SP3:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 31 of 33
danirent
 why my edit page dessapeared, I'm using autocad 2013.
Message 32 of 33
sweetpimft
I have the same problem.  Have there been any fixes?
Message 33 of 33
maxim_k
in reply to: sweetpimft
Can you specify your macOS version and AutoCAD version?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
