Hi there, I have autocad 2013 on my mac and i'm a student. My distance tools are all not working no matter what I do, any suggestions?
Thank you
-Amanda
Welcome to the Autodesk Forums!
Hi Amanda,
@Anonymous wrote:
My distance tools are all not working no matter what I do..
Could you provide more details?
What do you mean by "distance tools"? Is it MEASUREGEOM command? Or DIST command? Or dimension commands?
And how them not working? Please, provide your steps.
Maxim
I've had this problem for months one day it just stopped working but it doesnt matter if it's a new drawing or an imported drawing I cant measure the length of any line... using any measuring tool in cad. If i draw a line I can dype DIST and but the curser doesnt change it just stays the same and it wont let me pick a point to start it just clears the command box as if I never typed it.
Could you post Command line output when you call DIST or MEASUREGEOM command?
In my case it looks like:
Command: DIST Specify first point: <Osnap on> Specify second point or [Multiple points]: Distance = 14.6519, Angle in XY Plane = 29, Angle from XY Plane = 0 Delta X = 12.8139, Delta Y = 7.1051, Delta Z = 0.0000 Command: *Cancel* Command: MEA MEASUREGEOM Enter an option [Distance/Radius/Angle/ARea/Volume] <Distance>: D Specify first point: Specify second point or [Multiple points]: Distance = 14.6519, Angle in XY Plane = 29, Angle from XY Plane = 0 Delta X = 12.8139, Delta Y = 7.1051, Delta Z = 0.0000 Enter an option [Distance/Radius/Angle/ARea/Volume/eXit] <Distance>: X Command:
Maxim
