So I got the Autodesk Suite as a student, I haven't had AutoCAD 2015 for too long. Whenever I'm adding dimensions to my drawing, they do not show up as they do on Windows, despite my visits to the dimension style menu. Also, when I export it as a PDF, they don't show up at all.
Attached is a screenshot of what I am talking about.
Any help would be much appreciated.
Solved by maxim_k. Go to Solution.
Thank you!
Is there any way I can access this dimension style from the toolbar or do I always have to go to the menu bar?
@Anonymous wrote:
Thank you!
You cannot in OOTB configuration, but you can use CUI command to add DIMSTYLE command to ToolSets palette:
Maxim
