I just downloaded and installed AutoCad 2013 for MAC. I've yet to sucessfully use the program because everytime I open the 'Dimension Style Manager' to adjust dimension standards (switch from Decimal to Architecture) and then 'close' the manager it crashes the program EVERY TIME - even if I don't change anything, it crashes. Is there a bug in the 2013 version I need to download a fix for or something? Incredibly frustrated as I cannot send out drawings with decimal dimensions and no other MAC software is available for download. Suggestions?
Thanks!
Maverick, latest MAC OS: currently not supported with 2013 until the beta patch becomes official sometime this year.
Try posting in the MAC forum after a search to see if your issue is known already: http://forums.autodesk.com/t5/AutoCAD-for-Mac/bd-p/520
I do have 10.9.1. I apoligize. Is the dimension style manager the only part incompatible? b/c i can draw all day without any problems until I open dimension style manager, and then it freezes? Is it possible to go back to an older software version? b/c I have never had this problem before? or is my only option to get AC 2013 or2014? Thanks for the help.
I have the same problem with the Dimension Style Manager, but still you can change the properties of the Dimension Styles thourgh the Properties Inspector, it will give you all the options the Style Manager does but you cannot create or modify the styles, hope it'll help you while the problem gets fixed.
hi,
i have autocad 2013 version,and macbook pro(2009mid) but with osx yosemite
while changing style dimensions and working with autocad it just freezed and i couldnt go on! what shoul i do?
HI,
I am having the same problem, but I have El Capitan version 10.11.3.
But this is a new issue, I was using cad perfectly fine, no problems and then all the sudden today it started freezing up and not the program crashed everytime I try to "modify" the Standard dim style.
Any ideas?
Thank you!
