AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Custom ctb crashes when plotting
6 REPLIES 6
ryanwhitacre
948 Views, 6 Replies
If I plot to the Mac OS X built-in PDF printer using one of our custom .ctb files, during the "regeneration" phase of the plot, AutoCAD for Mac crashes.  If I use the same .ctb file to print directly to a physical printer, it works just fine.  The built-in .ctb files (grayscale, monochrome, etc.) from the Windows version will allow for the pdf plot to go through, but of course without our lineweight settings. Any thoughts on what may be causing this?
6 REPLIES 6
maxim_k
in reply to: ryanwhitacre
Could you post your .ctb file? I'll try to investigate problem. Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ryanwhitacre
in reply to: maxim_k
Thanks, Maxim. Attached is one of our .ctb files, but all are encountering the same issue.
maxim_k
HI,
I have tested your ctb file and in my case AutoCAD does not crash at all. (As I have no of your files, I have made test file with all colors from 1 to 255).
I also have noticed, that your ctb file is rather old (2005) and I have noticed in it strange settings for Lineweights:
Also could you test ctb file edited by me? It is in attachment.
Please, post results, if possible.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
ryanwhitacre
The file you attached crashed as well.  However, I made a copy of one of the included .ctb files (monochrome.ctb) and started changing some of the settings until I got it to crash.  When I changed the Line Join Style to "mitre" the crash would occur.  So, I took our custom pen style files and changed the Line Join Style from "mitre" to "use object style" and it didn't crash anymore.  So, it seems like a bug is in there for the Line Join Style.
maxim_k
Congratulations!
But it is really strange, that on my system I have no crashes.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Thank you so much!  I was having the same issue and after changing the line join style I can use my ctb style without crashing.  This only started happening to me after the last update so hopefully they will be able fix it soon.
”Boost
