AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
cursor & selection settings reset
3 REPLIES 3
564 Views, 3 Replies
Hello all,
is there a way to reset the cursor & selection settings ?
Mine have changed, I don´t know why. tried to adjust the settings but it´s only a pain now.
doesn´t matter what I adjust, it`s very hard to snap and I have to hold the cursor quite long over a point / node / midpoint etc. till it snaps to it.
I wish I could go back to the default settings!
3 REPLIES 3
maxim_k
Welcome to Autodesk Forums!
AFAIK there is no System variable that controls the delay for object snap.
The only one thing you can set is the size of the object snap target box - you use APERTURE command to set this value: the higher the number, the larger the target box and Autosnap works quicker. Type at the command prompt APERTURE, hit Return, then enter the value, than hit return again.
The default value is 10.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Thank you Maxim,
what is the default for pickbox size and autosnap marker or can you recommend something?
maxim_k
I use PICKBOX=5 and APERTURE=10
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
