hi,
when i use copyclip command & select object its take time for selection,
I mean when i select an object AutoCAD slows down sometime hang also
If I insert this file as xref to another file it takes time also.
If anyone knows the solution please please let me know.
Thanks in Advance
A.
Solved by maxim_k. Go to Solution.
hi,
thanks for your reply.
I tried Audit & WBlock the whole file but it has the same problem.
so I am attaching this file for your investigation
A.
Your drawing was full of AcDgnLS proxy objects:
Simple -WBLOCK command with * option cleared them:
Command: -WBLOCK
Enter name of existing block or
[= (block=output file)/* (whole drawing)] <define new drawing>: *
Command:
See attached DWG. Does delays gone away on your side?
Maxim
