AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
copy to layer
5 REPLIES 5
JohnRennie
3158 Views, 5 Replies
copy to layer
What's happened to copytolayer?
It is also missing from the "missing command list"
It is not an express tool as it was incorporated in AutoCAD a few years / releases back
5 REPLIES 5
maxim_k
in reply to: JohnRennie
Hi John,
Try my rough Lisp file (no error checking, don't change cmdecho, etc.) See attachment.
Load COPYTOLAYER.FAS (Tools -> Load Application)
Type COPYTOLAYER at command prompt.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
JohnRennie
in reply to: maxim_k
Many thanks, works fine for me.
Hopefully they will have it embedded in the next release
MaltbyDesign
Does this work for Autocad for Mac 2016? I thought I loaded it yesterday, but when I tried using it today the command didn't exist. Would you mind walking me through the proper procedure for loading this file so that it stays without re-loading it each day?
Thank you for your help.
maxim_k
Welcome to Autodesk Forums!
If you want to load AutoLISP routine each time you start AutoCAD or open new (or existing) drawing, you can add it to "Startup Suite" from Load Application window (APPLOAD command):
https://knowledge.autodesk.com/support/autocad-for-mac/learn-explore/caas/CloudHelp/cloudhelp/2016/E...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
MaltbyDesign
Thank you for your help. I think I have it sorted.
”Boost
