AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
comprehensive list of commands and settings
2 REPLIES 2
margie_lo
906 Views, 2 Replies
Does anyone have a comprehensive list of standard key in commands and all the various settings options?  For example when you key in selectionmode and can select the numbers from 0-2.  What exactly does each number translate too?  I just haven't been able to commit it all to memory.
Thanks!
2 REPLIES 2
maxim_k
in reply to: margie_lo
I think, that:
- online or offline Help system is the best way to get information about command options and System variables settings, just start a command, or enter variable name at the command prompt (hit Return) and then hit F1 key - Help will opens on corresponding page with description of all options (or variable settings);
- PDF documentation could serve as a kind of comprehensive list that you can take with you everywhere (just put it to your tablet or smartphone Smiley Happy ), you can download documentation from here (look for "Command Reference" at first):
http://docs.autodesk.com/ACDMAC/2013/ENU/PDFs/PDF%20Documentation.htm - for AC 2013 for Mac
http://docs.autodesk.com/ACDMAC/2012/ENU/PDFs/PDF%20Documentation.htm - for AC 2012 for Mac
http://docs.autodesk.com/ACDMACLT/2013/ENU/PDFs/PDF%20Documentation.htm - for AC LT 2013 for Mac
http://docs.autodesk.com/ACDMACLT/2012/ENU/PDFs/PDF%20Documentation.htm - for AC LT 2012 for Mac
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
margie_lo
in reply to: maxim_k
Thanks.  That's exactly what I needed.
”Boost
