AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Comman move deform the lines
1 REPLY 1
r.bragadesouza
1215 Views, 1 Reply
Could someone helo me. I use Autocad 2014 for MAC, and, sometimes, when moving an object using MOVE the objects gets deformed. It's like the edge of the line are connected to that point and the likes move, but the edges don't. There's an image attached to show the problem.
Thank you
1 REPLY 1
maxim_k
in reply to: r.bragadesouza
Welcome to Autodesk Forums!
Please verify that parametric constraints are not applied to objects in your drawing. You can delete constraints from Parametric menu, if you don't need them at all, than use "All" option when you will be prompted to select objects to delete constraints,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
