AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Cant' print at all (PDF, PRINT or PRINT PREVIEW)
19 REPLIES 19
Message 1 of 20
587 Views, 19 Replies
Trying to print a PDF in AutoCAD LT Mac 2014.
I have tried printing a PDF in preview (through the print dialog) and also exporting to PDF. Neither work. Cant print to a printer either. This is on OSX 10.9.3 and the latest update for LT 2014.
19 REPLIES 19
Message 2 of 20
maxim_k
Welcome to the Autodesk Forums!
Could you provide more details?
What happens when you pick on Preview button in Print window?
Does AutoCAD freezes? Do you see additional small window with print progress:
Or nothing happens?
What printer are you using for Page Setup?
Do you use Custom paper size for your Page Setup?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 20
in reply to: maxim_k
Preview drops me back to the drawing. No print progress bar.
I have 3 printers installed. 2 colour A3 canon printers and an A0 Canon plotter. All network printers
No custom paper, just A3.
Message 4 of 20
maxim_k
Which printer is current when you are trying to preview from Print dialog?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 20
I've tried all 3...
Message 6 of 20
maxim_k
Post here screenshot of Print dialog just before you pick Preview.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 20
Here you go:
Message 8 of 20
maxim_k
Could you try to create Custom Paper size (hope you know how to do this) - you can select from presets A3 paper size, adjust non-printable area, give this Custom Paper size some name, so you can recognise it.
Assign this Custom paper size to the page setup you are trying to print.
Open Print dialog, verify that your Custom paper size is selected in Paper size drop down list (if not - select it).
Try to preview.
What you get?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 20
when i try that the custome paper is set in the page manager, but when i go to the print dialog, custom paper sizes are grayed out (although it is set to custom) if i try preview now, it still just drops me back to the drawing.
Message 10 of 20
maxim_k
What do you mean by "grayed out"?
You can not select them from the list?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 20
I can select it in the page manager but not in the print dialog before I preview: see screenshot (details of the paper size seem correct though)
Message 12 of 20
maxim_k
And another step - have you tried to use Batch publish to PDF?
You can open Quick view drawings window, select two or more Layouts, right-click on them and select Print, in Batch publish dialog you can remove unnecessary Layouts from Batch list, set publish to PDF, select where files will be saved, select "Create Individual PDFs per Layout" and pick Publish.
What do you get?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 20
Tried that earlier...
But just tried again and whilst it looks like its doing something, I get the publish job progress, then a continous plot log could not be opened for write error. Nothing gets saved and theres no file where I set it to be saved to.
Message 14 of 20
maxim_k
Something is wrong on your Mac with Printing System.
You should be able to manage Custom paper sizes even from Print dialog in AutoCAD, here how it looks on my Mac:
What do you get in VIEWPLOTDETAILS after you Batch publish?
Are you able to manage Custom paper sizes from other application on your Mac, for example from TextEdit?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 20
I Can select the custom sizes in other applications yes.
I get "there are no plot or publish details to view" when i view VIEWPLOTDETAILS
Message 16 of 20
maxim_k
Try to create new user account on your Mac (with admin privileges)
Then login to this new account, launch AutoCAD and try to save PDF (you may need to copy your test DWG to external disk (USB stick) because you may not be able to open files from your main account.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 17 of 20
maxim_k
I have also additional questions:
- You wrote: "I get the publish job progress, then a continous plot log could not be opened for write error." - what plot log do you mean?
- What kind of account you have on your Mac (the account where you can not print from AutoCAD)? Are you log in as root by chance?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 20
Ok, It works through a different user account. Is there any way of repairing this? As were on a corporate network and its not something i can just recreate.
Thanks for all the help by the way, really appreciated!!
Message 19 of 20
I get an error message when doing the batch that it cannot write to the plot log.
Were on a corporate network so no root that i'm aware of.
Message 20 of 20
maxim_k
I think you have permissions problems in your original account, but dealing with permissions is very responsible task, so I can not advice you anything without been near your machine, sorry about this...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
