I want to save or export my drawings to PDF.
I have a drawing and I want to save as PDF but when I try to print it a print screen appears, I choose every settings then I select save as pdf but print screen disappears.
I learn that I can export to pdf so I tried it. But it has also a problem. In my drawing I drawed rectangles on A2 paper size(scale 1:20) to print it easily. But when I exported the drawing, it is not centered on page so a part of my drawing is not on paper.
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
The issues you have with saving to PDF from Print dialog and with exporting to PDF are because of the bug in AutoCAD 2014 for Mac when you use it on Mavericks and use Custom paper size for Page Setup (or for printing). Seems you are using Custom Paper size (isn't it?)
You need to install SP2, which seems "repair" this bug. Did you install SP2?
You can use "Check for updates from AutoCAD 2014" menu to get notification about SP available. Or download it from here:
Maxim
Service pack 2 has been installed already.
I can export pdf but I want to center drawings on page. Is there a way to center drawings on page when exporting to pdf?
If I use Current page setup and export Current page layout:
everything works fine on my side - the drawing centered on page as I set it in Page setup for Layout I'm exporting.
Maybe you have troubles if:
- you are using standard paper sizes for exporting which have non-printable areas, then your drawing will "shift" according to the sizes of this non-printable areas:
- you are using page size bigger then you have in Layout you are trying to export, then resulting drawing will shift to the edge of printable area of paper size you selected for override:
Maxim
Hi, I have the same problem and I cant plot any PDF file even though my AutoCAD is up to date. This is the screenshot that appears, and I dont know how to solve it because any of those options cant be modified
Please help me,
Thank you very much
Is it necessary for me to have Adobe Acrobat installed in order to print PDF's correctly?
thanks again
When do you see this message?
If it is in Page Setup Manager, than the information you have means that you don't have any printer (plotter) software installed on your Mac (Printers & Scanners pane of Mac OS System preferences). But even without printer software installed on your Mac you should be able to save to PDF from AutoCAD.
No, not necessary
Maxim
At first:
To write on the forum about pirated software is mauvais ton
About problem with custom paper size in Print dialog:
Yes it is a kind of a bug that appeared if you use AutoCAD 2014 for Mac on Mavericks: even if you will create Page Setup with Custom Paper size and then will try to print (save to PDF) from Print dialog with this Page Setup, the paper size resets to the nearest paper size available in current printer software and you need to chance it by hand each time you use Print dialog:
On the other hand if you will use Batch Publish or Export to PDF (menu File -> Export) custom paper size will not be loosen during printing or PDF export.
Maxim
Thank you very much and sorry about the software... I've noticed that you have printer installed, is it really necesary to have one? or can I just print to PDF without any print installed?
