AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Can't open AutoCad 2013 for Mac
27 REPLIES 27
Message 1 of 28
daccordo
9274 Views, 27 Replies
Cannot open the program. It happened after I was backing up files on an external hard drive. I got message that Autocrat could not continue, asked if I wanted to save the files for recovery ( I opted not too ), and will not open. I get the error report that "a software problem has caused AutoCad to close unexpectedly." It was working fine up until this point.
I sent the report. I have Mac OS X 10.7.3
I read that there is a conflict with some Adobe software which I have but cannot find the way to get rid of the FLEXnet folder.
Any one out there with a solution?
Thanks in advance.
27 REPLIES 27
Message 2 of 28
maxim_k
in reply to: daccordo
I think it is not FLEXnet issue in your case, but rather this one:
AutoCAD will not launch following a crash on Mac OS X (Lion)
Have you tried this solution?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 28
daccordo
in reply to: maxim_k
Still doesn't work. Should there be spaces between words and slashes? Thanks daccordo
Message 4 of 28
maxim_k
cd ~/Library/Saved\ Application\ State
- spaces are between "Saved\" and "Application\" and between :Application\" and "State"
If it will not work, could you post Console output during AutoCAD launch?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 28
daccordo
Is there no space between cd and ~? I left no space the first time and got ...no such file or directory. With the space I get ? Saved Application State. Try to launch program, still doesn't open. daccordo
Message 6 of 28
maxim_k
Yes, there is a space.
Have you run all three commands from the support topic?
then
rm -rf com.autodesk.AutoCAD.savedState
then
rm -rf com.autodesk.autocadlt.savedState
After running the first you should have:
"name of your mac": Saved Application State "short user name"$
in my case it looks:
Maxim-Kanaev-2: Saved Application State max$
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 28
daccordo
Yes, that's what I get. I close down the terminal and try to open but no luck
daccordo
Message 8 of 28
daccordo
How does one post Console output during AutoCAD launch? Have no idea what this does or means.
daccordo
Message 9 of 28
daccordo
Here's another thing... all my acad file icon, the silver A and red background, have changed to a illustratorish one with DWG in orange and a see through silver cube and the icon.
Message 10 of 28
maxim_k
Could it be this:
AutoCAD for Mac fails to launch when installed on migrated Mac hard drive
About Console.app - here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-for-Mac-2012-Trial-Download-won-t-launch/m-p/3...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 28
daccordo
Could it be this:
Tried this and terminal said "command not found".
Message 12 of 28
maxim_k
Try to copy this string and paste it to Terminal window:
sudo mv /Library/Preferences/FLEXnet\ Publisher /Library/Preferences/FLEXnet\ Publisher_old
Press return and provide the admin password when prompted.
Should work!
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 13 of 28
daccordo
Last login: Tue Jul 3 09:45:16 on ttys004 Domenicos-MacBook-Pro:~ domenicocomacchio$ sudo mv /Library/Preferences/FLEXnet\ Publisher /Library/Preferences/FLEXnet\ Publisher_old mv: rename /Library/Preferences/FLEXnet Publisher to /Library/Preferences/FLEXnet Publisher_old/FLEXnet Publisher: No such file or directory Domenicos-MacBook-Pro:~ domenicocomacchio$ Thanks daccordo
Message 14 of 28
maxim_k
OK, you don't have FLEXnet preferences folder at all.
Have you ever run AutoCAD on your Mac, or it can not start even for the first time in order to start activation process?
What about Console?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 15 of 28
Mine failed to launch when migrated onto new mac and I tried the solution for that but I have no Flexnet folder.  It was running fine before migrating and haven't been able to open it since.  Adobe reader works ok, not sure if that's relevant.
Please advise
Message 16 of 28
Hi guys,
I'm having an issue as well!!  I've been use AutoCad 2013 on my imac for a while and suddenly it won't launch.  I've unistalled and tried to re-install, but to no avail it doesn't work?  Is there any resolve to this??
Here's the ERROR LOG:
Process: AutoCAD [53038]
Path: /Applications/Autodesk/*/AutoCAD 2013.app/Contents/MacOS/AutoCAD
Identifier: com.autodesk.AutoCAD
Version: 19.0.55.108 Copyright © 2009-2012 Autodesk, Inc (19.0.55.108)
Code Type: X86-64 (Native)
Parent Process: launchd [125]
Date/Time: 2013-10-14 12:58:16.646 -0400
OS Version: Mac OS X 10.7.5 (11G63)
Report Version: 9
Interval Since Last Report: 343445 sec
Crashes Since Last Report: 19
Per-App Interval Since Last Report: 614778 sec
Per-App Crashes Since Last Report: 18
Anonymous UUID: 59720380-36C4-4392-A183-26FF574C45C6
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: @rpath/libgelib.dylib
Referenced from: /Applications/Autodesk/*/AutoCAD 2013.app/Contents/MacOS/AutoCAD
Reason: image not found
Binary Images:
0x100000000 - 0x1000b0fff +com.autodesk.AutoCAD (19.0.55.108 Copyright © 2009-2012 Autodesk, Inc - 19.0.55.108) <2778DA86-5424-5A9C-22E3-B7E2EF292452> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/MacOS/AutoCAD
0x1001af000 - 0x1001b2fff +libCocoaAPI.dylib (??? - ???) <D72A1A98-97FC-6427-45B4-B98EEAB9A9D7> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libCocoaAPI.dylib
0x1001b6000 - 0x1001b7fff +libQtAPI.1.dylib (??? - ???) <74B54F1F-7767-557C-3DB8-E813D52DE79E> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libQtAPI.1.dylib
0x1001bb000 - 0x101e56fe7 +libacdb.dylib (??? - ???) <4A28221F-2C80-6518-05DC-3C005DD6A1EE> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libacdb.dylib
0x103a46000 - 0x103a4fff7 +libAdHostableUi.dylib (??? - ???) <8EBBF92F-49B1-A94D-70CF-94EC240237AA> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libAdHostableUi.dylib
0x103a67000 - 0x1048fbfef +libaccore.dylib (??? - ???) <17E35F06-8D25-0AF4-66F2-FE2AA54A5EAF> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libaccore.dylib
0x105506000 - 0x105548ff7 +libacfirst.dylib (??? - ???) <B0CBD18F-1451-CBC7-D886-8360DAD08CE7> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libacfirst.dylib
0x1055c2000 - 0x1055d9fff +libadASM.dylib (??? - ???) <3655B749-6A45-E86C-E3F9-39DEEB4A438F> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libadASM.dylib
0x1055fb000 - 0x105a6dfef +libAdImaging.dylib (??? - ???) <5501DD10-0846-E58B-CBE1-2FB2A087BF6D> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libAdImaging.dylib
0x105f34000 - 0x105f54ff7 +libAdIntImgServices.dylib (??? - ???) <0D5B62E9-91A6-1168-E575-AA859E9397F6> /Applications/Autodesk/*/AutoCAD 2013.app/Contents/Library/libAdIntImgServices.dylib
0x7fff65586000 - 0x7fff655babaf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
Model: iMac12,1, BootROM IM121.0047.B1F, 4 processors, Intel Core i5, 2.5 GHz, 12 GB, SMC 1.71f22
Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 512 MB
Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620
Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x02FE, 0x45424A3230554638424353302D444A2D4620
Memory Module: BANK 0/DIMM1, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
Memory Module: BANK 1/DIMM1, 4 GB, DDR3, 1333 MHz, 0x01BA, 0x202020202020202020202020202020202020
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x9A), Atheros 9380: 4.0.67.5-P2P
Bluetooth: Version 4.0.8f17, 2 service, 18 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en1
Network Service: Leapfrog Device (en3), Ethernet, en3
Serial ATA Device: WDC WD5000AAKS-402AA0, 500.11 GB
Serial ATA Device: OPTIARC DVD RW AD-5690H
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfa100000 / 3
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0xfa110000 / 4
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0xfa111000 / 6
USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x850b, 0xfa200000 / 2
USB Device: hub_device, 0x0424 (SMSC), 0x2514, 0xfd100000 / 2
USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd120000 / 4
USB Device: Internal Memory Card Reader, apple_vendor_id, 0x8403, 0xfd110000 / 3
Thanks in advance!
Message 17 of 28
maxim_k
Welcome to the Autodesk Forums!
You wrote: "I've been use AutoCad 2013 on my imac for a while and suddenly it won't launch."
What does it mean "suddenly"? Have you changed something in your System? (updates, software installation)
Do you have Time Machine backup? Can you restore your Mac to the date, when AutoCAD was function properly?
When you tried to remove (uninstall) AutoCAD: did you unchecked "Leave AC preferences..." in uninstallation dialog? If no - try to uninstall with removing preferences.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 18 of 28
Yes, I've uninstalled the application both ways: leaving the ac checked and then unckecking. I'm see library error or something...dylib?? Make any sense to you. FYI, I humored autodesk and installed 2012. It worked but my kasperske antivirus is roaring like crazy as the same with 2013; when installing the application??
Thanks alot for your insight...I've got projects to work on!!
Jacob
Message 19 of 28
maxim_k
Hi Jacob,
I think there is an update on your issue with AutoCAD for Mac 2013.
Look at this topic:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-2013-trojan-on-library/td-p/4523339
It appears, that Kaspersky antivirus works "against" AutoCAD for Mac and gives a false alarm, further more it moves one of the dynamic library file (essential to AutoCAD) to quarantine, and this prevents the launch of the application.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 20 of 28
Thanks for looking into this problem, Maxim! I actually figured the problem out and derived the same solution you just mentioned.
So for future inquiries from others:
The issue is a false positive; meaning that the program is recognizing a threat, but the threat is an unresolved issue from the download which does not effect the application or computer.
If anyone is having the same issue, try this:
1. Turn your Anti-Virus off before downloading AC [ In my case I'm using Kaspersky ]
2. Ignore the threat: /Applications/Autodesk/AutoCad 2013/AutoCad 2013.app/Contents/Library/libgelib.dylib
3. Proceed with the download
4. Once the download is successful, quarantine or delete any "false threats"
5. Start the AC application
6. Turn your Anti-Virus back on.
:This should do it:
Just a Recap: The anti-virus software was the actual issue in this case because of its mis-interpretation of the trojan threat within the AC library. Autodesk needs to address this issue, but I think if you follow the above-mentioned steps, the application should work! Definitely quarantine or delete the threat first, then startup AC, then turn the Anti-Virus back on!
Cheers and many thanks to Maxim for delving into the issue
”Boost
