I'd like to active annotative for the HATCH-command but whenever I give this command (or click HATCH in the Tool Sets palette) only a small window for just a few options pops up but not the big HATCH&GRADIENT window - like seen in the Training Videos. How can I change this? At the moment I can only access the big HATCH&GRADIENT window after I've created the hatching.
Help is really appreciated. Thanks a lot!
Greetings
Deissi
Solved by maxim_k. Go to Solution.
Hi Deissi,
If you mean Hatch Visor, that appears in AC for Mac 2012 and 2013, after you call HATCH command:
then in order to show Hatch Settings dialog, you have to type "t" (without quotes) at the command prompt and hit Return when AutoCAD asks to pick points, or right-click and select "seTtings" from context menu:
or select seTtings from Dynamic menu:
Maxim
Hello Maxim,
thank you so much for your help and detailed answer! This is exactly what I am looking for.
Greetings, Deissi
