AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Callout blocks HELP URGENT
8 REPLIES 8
Message 1 of 9
cleung2
3406 Views, 8 Replies
I know in AutoCad PC version, you can pull out the tools palette using ctrl+3 and use the callout bubbles (section/elevation/drawing title/detail etc) in the annotative tab. Does autocad for mac 2013 have that?? I can't find it anywhere. Also, we can't create dynamic blocks in cad for mac, can anyone suggest how I should go about making a detail bubble?
Thanks!
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: cleung2
Short Googing gave me this link:
http://www.cadlispandtips.com/2012/01/blk-dynamic-callouts.html
You should say many thanks to Bijoy Manoharan
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
david23SJB
in reply to: maxim_k
The file was really helpful. Is there a way to whiteout the text background of the callout to match so you can't see viewports/layers below?
Message 4 of 9
john.vellek
in reply to: david23SJB
HI @david23SJB,
Please share with me on a post,  the blocks you are using and I will see if I can do this with a textmask or a solid hatch set to a non-plotting color such as 255,255,255
John Vellek
Message 5 of 9
david23SJB
in reply to: john.vellek
File attached. Are there out of the box section/detail callouts within Autocad for Mac?
Message 6 of 9
john.vellek
Hi @david23SJB,
Try this block and see if it works for you. When you insert it you might need to adjust the Draw Order to make sure that it is the very "Front" object.  I created a circular wipeout inside the block and set it to be color 255,255,255.
John Vellek
Message 7 of 9
david23SJB
Thanks. How did you edit the block? When I double click on the callout it opens the 'Enhanced Attribute Editor' but doesn't allow me to edit the core block/linework.
Message 8 of 9
maxim_k
Hi David,
Right-click on selected block instance, then select "Block Editor" from context menu.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
john.vellek
Hi @david23SJB,
I am checking back to see if my post helped you with your problem or question. Were you able to open the blocks using Block Editor (BE) and add the hatch as I did with my sample? Please mark my post as the solution if it resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
”Boost
