Hi all
I am a mature Art student and I want to learn Autocad for some of my work.
However,
I know this must sound very basic, but I have just installed the package, but I cannot even open the interface!!
There is only the top bar were I can click on File. If I click on 'new project' or 'new drawing', it opens the dialogue box with all my files. None of those files are suitable to load, therefore nothing happens. Sorry but I cannot use this package whatsoever!
This is drastically dissapointing (not the software its my failure).
Any giudance at all would be much appreciated.
Brian
Solved by maxim_k. Go to Solution.
Welcome to the Autodesk Forums!
Theoretically you should see Welcome screen when you start AutoCAD for the first time:
You need to select CREATE tab, than select "New" on the left side, than select template file on which your drawing will be based (acad.dwt - for imperial units and acadiso.dwt for decimal units), than click on "Open" button/
But if this does not happen (you don't see Welcome screen) for some reason, and you select "New drawing" from File menu, than you should see this dialog:
ensure that you have "Drawing Template" in "File format" list selected, than select template file you need for your drawing to start new drawing.
Maxim
I appreciate your inclusion of the screenshots. I am now in the workspace.
I now need to find a tutorial that will take me from how to construct a room space divided into four seections.
Thanks again for yor help.
Brian
