AutoCAD for Mac General Discussion
Active Contributor
gregory
Message 1 of 6 (514 Views)
Batch Publish - Mac CAD 2013
514 Views, 5 Replies
01-22-2013 04:16 PM
I'm having trouble adding files to the Batch Publish when the files are on our server.  If the files are locally on my desktop, it has no issue...
anythoughts...
-G
Active Member
spirelighting
Message 2 of 6 (443 Views)
Re: Batch Publish - Mac CAD 2013
04-01-2013 11:36 AM in reply to: gregory
I have the same issue.   If a file is opened over a samba or AFP file share, batch publish fails to add anything to the batch publish window.  If the file is copied to the desktop, it works flawlessly...
Obviously something that fails to grab network shared files for the batch publish.
New Member
chrisminor
Message 3 of 6 (204 Views)
01-08-2014 09:23 AM in reply to: gregory
I am having the same problem.  Any luck finding a solution anyone?
Active Member
spirelighting
Message 4 of 6 (197 Views)
01-08-2014 09:44 AM in reply to: chrisminor
I figured out the steps to reproduce and then also to work around this bug.
If you save the document, you cannot add any of the layouts to the Batch Publish dialog box.  If after saving, however, you switch which layout you are on and try the batch publish again, it works!
So, moral of the story is "Save" and then switch the active layout and it will work.
Cheers!
New Member
chrisminor
Message 5 of 6 (192 Views)
01-08-2014 10:30 AM in reply to: spirelighting
Thanks for the response and work around, but that doesn't seem to be working for me.  I will keep searching to see if I can get it to work.  This is a critical function that I am going to lose if I keep my files on network storage.  Seems like a a terrible bug that Autodesk should correct.
Active Member
spirelighting
Message 6 of 6 (191 Views)
01-08-2014 10:42 AM in reply to: chrisminor
Yes. I agree it is a bug that needs to be fixed. There are several bugs
like this that i hope are fixed soon.
Seth Shoemaker
Technical Designer
Spire Lighting Design, LLC
seth@spirelightingdesign.com
717-549-3649 - office
717-585-8488 - cell
Announcements
Need installation help?
