I'm having trouble adding files to the Batch Publish when the files are on our server. If the files are locally on my desktop, it has no issue...
anythoughts...
-G
I have the same issue. If a file is opened over a samba or AFP file share, batch publish fails to add anything to the batch publish window. If the file is copied to the desktop, it works flawlessly...
Obviously something that fails to grab network shared files for the batch publish.
I figured out the steps to reproduce and then also to work around this bug.
If you save the document, you cannot add any of the layouts to the Batch Publish dialog box. If after saving, however, you switch which layout you are on and try the batch publish again, it works!
So, moral of the story is "Save" and then switch the active layout and it will work.
Cheers!
Thanks for the response and work around, but that doesn't seem to be working for me. I will keep searching to see if I can get it to work. This is a critical function that I am going to lose if I keep my files on network storage. Seems like a a terrible bug that Autodesk should correct.
