AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
autocad redrawing object slowly
6 REPLIES 6
rgwhatley
5010 Views, 6 Replies
Autocad has just started this wierd thing where if I move an object it disapears and starts redrawing it line by line very slowly. What's going on?
6 REPLIES 6
Leaf.chai
in reply to: rgwhatley
Hi User,
Please check your sysvar DRAGP1.
If the value is 0, pls try to change it to 5000.(default value)
Hope it is useful for you.
Leaf Chai
AutoCAD QA Analyst
rgwhatley
thankyou. I discovered what was wrong last night just after i posted. My second question now is why do my settings keep randomly changng on their own accord? I've had this sort of thing happen before. (The dragp1 was set to 0 yet I didn't change it.)
maxim_k
Do you use custom AutoLISP routines?
Sometimes this could be the case: suppose that for some reason the author of routine change some of system variables for it's own need inside Lisp routine and doesn't revert back them to default values when the routine ends.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
rgwhatley
in reply to: maxim_k
I don't use lisp routines, this was in LT. Before I was using standard autoCAD yet the same thing kept happening.
maxim_k
OK, sometimes application crashes can lead to changes in system variables....
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Charles_Shade
Something new everyday:
http://docs.autodesk.com/ACDLT/2013/ENU/files/GUID-E2A80E69-A30A-439C-B909-E5CAA3E220F2.htm
Maxim_k is indicating something that may be going on if this is happening and has happened in the past.
Do you have any Macros or Script routines that you use regularly?
Did you bring any of these from AutoCAD to the LT seat?
There could be a setting in one of these that triggers the setting of the Variable to 0.
”Boost
