Hey so, I moved from OLD Autodesk Architectural Desktop 2005 on PC to AutoCAD LT 2014 on Mac. I have been using it the last few months and like a lot of things. However, I have found one thing I do not like is when I click into one of my block attributes with text it does automatically highlight and click into the specific text on the block.
For example:
I would click on my block like, "First Floor Plan" and it would go straigh to that text to edit it. Now when I double click on the "First Floor Plan" it does not highlight and take me directly to it. I now how to select it and then edit it.
With that said I use to be able to hit 'enter' after editing each part and it would take me to the other attributes by hitting 'enter' after editing each part. Now I have to select each one.
I know it's not much but it sure is annoying to have to do more work in the new version to get little things done.
Is this a setting somewhere I can change or programming that I can't change easily?
Solved by maxim_k. Go to Solution.
