AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD LT 2015 with Yosemite 10.10.1 crashing despite Update 2?
7 REPLIES 7
Message 1 of 8
660 Views, 7 Replies
Hi there,
I have installed Yosemite 10.10.1 and AutoCADLT2015Update2_English.dmg but AutoCAD LT continues to crash!!
Does anyone know if any more updates on the way?
Cheers,
o
7 REPLIES 7
Message 2 of 8
maxim_k
Please describe your problem in more details.
When it crashes?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 8
in reply to: maxim_k
It's crashing almost every time I try to open a drawing, be it through
'File > Open' or Project Manager. It also crashes if I attempt to relink an
Xref.
I have tried checking the 'Activate OpenGL Core Profile' checkbox as
advised in a previous post
(/Users/oliviamoore/Library/Caches/TemporaryItems/A$C399C4022.DWG) but to
no avail.
Any help appreciated - it's just crashed AGAIN!
Thanks!
o
Message 4 of 8
maxim_k
Have you tried to reset AutoCAD?
Please describe your hardware - your Mac model, how much RAM do you have, etc.
Do you open DWG files from local disk or from Network drive?
How complex are the files that crashed AutoCAD on opening or relinking Xrefs?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 8
wei503
It is a known issue that on Yosemite, the Select File dialog crashes a lot. We have logged the bug to Apple, but the issue is not resolved yet. Please try the workaround in the following page and see if it helps.
http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
Wei
Wei Ma
AutoCAD for Mac QA Manager
Message 6 of 8
Thanks for looking into this!
No, I haven't tried resetting AutoCAD but will give that a go.
My Mac is a Mac Book Pro from way back in 2011 but has had a wee upgrade:
2.3 GHz Intel Core i5
8 GB 1333 MHz DDR3
Intel HD Graphics 3000 512 MB
I am opening the DWG files from a local disk and they are very simple drawings...one or two I tried opening only had a handful of lines in them!
Cheers,
o
Message 7 of 8
in reply to: wei503
Thanks, will try this too.
o
Message 8 of 8
maxim_k
Most likely Wei is right in his assumption about column view in Open dialog.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
