I'm using Autocad Lt 2013 and installed the latest mavericks update (10.9.2) this morning and worked in autocad fine until my computer crashed hours later. After forcing autocad to quit after the program locked up, I restarted my computer and now Autocad will not start. I searched this forum for a solution and saw a post about the same problem but that post referenced deleting a flexnet file folder which I do not have. I have since reinstalled Autocad but still have the same problem. Everytime I start the program, it immediately creates an error report and will not start. Please help!!!!!!
Solved by magmcA. Go to Solution.
Thanks Maxim.
Yes, I had all the service packs installed prior to the crash. I have also reinstalled it and unchecked the box "leave AutoCAD preferences" and get the same result. It starts loading and then automatically creates a report error page.
From console app
3/10/14 4:33:49.261 PM FNPLicensingService[808]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
3/10/14 4:33:49.529 PM LMU[809]: 809 DAEMONIZE: setting umask 0
3/10/14 4:33:49.529 PM LMU[809]: 809 DAEMONIZE: session parent exiting
3/10/14 4:33:49.529 PM LMU[809]: exiting and supressing hooks: 0
3/10/14 4:33:49.529 PM LMU[810]: 810 DAEMONIZE: session new session leader
3/10/14 4:33:49.530 PM LMU[810]: 810 DAEMONIZE: tty disconnect parent exiting
3/10/14 4:33:49.530 PM LMU[811]: 811 DAEMONIZE: tty disconnect child
3/10/14 4:33:49.530 PM LMU[811]: 811 DAEMONIZE: closing file descriptors
3/10/14 4:33:49.530 PM LMU[811]: 811 Execing /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/lmuopen
3/10/14 4:33:49.530 PM LMU[811]: 811 with argument: lmuopen
3/10/14 4:33:49.531 PM LMU[811]: 811 with argument: /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/LMU
3/10/14 4:33:49.542 PM lmuopen[811]: Launching: /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/LMU
3/10/14 4:33:52.000 PM kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Resume -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0x4400 ****
3/10/14 4:33:54.507 PM WindowServer[86]: CGXSetDeferredUpdates: Default deferred updates value: 1
3/10/14 4:34:33.000 PM kernel[0]: **** [IOBluetoothHostControllerUSBTransport][SuspendDevice] -- Suspend -- suspendDeviceCallResult = 0x0000 (kIOReturnSuccess) -- 0x4400 ****
3/10/14 4:34:39.777 PM LMU[810]: exiting and supressing hooks: 0
3/10/14 4:35:01.785 PM com.apple.IconServicesAgent[195]: main Failed to composit image for binding VariantBinding [0x43d] flags: 0x8 binding: FileInfoBinding [0x215] - extension: jpeg, UTI: public.jpeg, fileType: ????.
3/10/14 4:35:01.785 PM quicklookd[879]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: VariantBinding [0x603] flags: 0x8 binding: FileInfoBinding [0x503] - extension: jpeg, UTI: public.jpeg, fileType: ???? request size:16 scale: 1
3/10/14 4:35:01.801 PM com.apple.IconServicesAgent[195]: main Failed to composit image for binding VariantBinding [0x105] flags: 0x8 binding: FileInfoBinding [0x3e7] - extension: gif, UTI: com.compuserve.gif, fileType: ????.
3/10/14 4:35:01.802 PM quicklookd[879]: Warning: Cache image returned by the server has size range covering all valid image sizes. Binding: VariantBinding [0x803] flags: 0x8 binding: FileInfoBinding [0x703] - extension: gif, UTI: com.compuserve.gif, fileType: ???? request size:16 scale: 1
3/10/14 4:35:23.251 PM com.apple.launchd.peruser.502[136]: (com.autodesk.AutoCAD_LT_2013.32064[766]) Exited with code: 254
I searched for it in finder first on my entire hard drive and came up empty. It is not located in the Preferences folder in the Library folder either. ?????
Please help!!! I had a similar issue and have tried everything that you suggested and my autocad still won't open.
cgrove,
My problem was a license manager issue. It occured again about a month ago and I had to uninstall AutoCad and reinstall it and then reinstall all the updates again. After that it worked fine.
The following link helped me: http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
I hope this helps!
magmcA
