I had to re-install my macbook, now OSX 10.9.4
I have run the LT 2013 install - Autocad will now not launch (bouncing dock icon that eventually times out)
Sadly when I run the Service pack 1 and 2 installers they fail with the helpful message "The Updater has failed" - see screenshot attached.
Any words of wisdom gratefully received.
Jon
Solved by jon.crew. Go to Solution.
This is really helpful, thank you.
So using the downloaded installer I can now run autocad again which is a big step forward.
I still get the "updater failed" message when running SP2 though.
Actually .. this fixed it:
1.) Navigate to folder /User/Shared/
2.) Remove the folder _adsk with sudo command:
sudo rm –f _adsk
3.) Try to re-install the service pack
All good now !
