AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD LT 2012 Print Freeze
9 REPLIES 9
Message 1 of 10
534 Views, 9 Replies
Hello Everyone,
I do some IT work for a company who is currently running AutoCAD 2012 LT. I've never had to troubleshoot AutoCAD for them and have zero expierence. So, figured I'd turn to the community and try find some help.
The issue is when printing. The user will bring up the print dialog, setup his paper size, and then attempt to edit the page setup by clicking the "Edit Page Setup..." button. Once he clicks this button, nothing every happens. AutoCAD doesn't completely freeze, it's just useless until you force quit the application and reload it.
I have a hunch it can't pull up the Page setup dialog because it doesn't exist? Reason being is the label "Page Setup <None". Not completely sure though, just hoping for some suggestions. Screenshot attached.
Thanks!
9 REPLIES 9
Message 2 of 10
maxim_k
Welcome to the Autodesk Forums!
What OS do you have on your Mac?
If it is Mavericks (10.9.x), than this issue could be because of AutoCAD 2012 for Mac is not compatible with Mavericks.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
in reply to: maxim_k
Hi Maxim,
It's OS X 10.7.5.
Message 4 of 10
maxim_k
Does the Page Setup dialog goes away when you click on "Edit Page setup"?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 10
Yes, it goes away and no other dialog ever appears.
Message 6 of 10
maxim_k
It was knowing issue - but it was fixed with Service Pack 3.
Have you updated your AC 2012 for Mac installation with all Service packs from here
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=15839491
If in some case installing updates will not solve the problem, try to reinstall AutoCAD (don't forget to uncheck "Leave AutoCAD preferences" during removing existing AutoCAD installation.
For re-installation you can download installer from here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20452395&linkID=15839491
it already contains all SP integrated.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 10
Thank you Maxim. Feels like we are getting somewhere, however starting with SP1 so I can install 2 & 3, it's reporting that AutoCAD 2012 could not be found. Do the service packs apply to the LT versions as well?
Message 8 of 10
maxim_k
Sorry, I pointed you in wrong direction.
If you have AC LT purchased from Autodesk, try to run Check for Updates command from AutoCAD LT menu to ensure that you have most recent version of SP installed.
But at first - try simply to reinstall AutoCAD LT.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 10
Trying a reinstall. It turns out they purchased through the App Store and the Update option would just report back an error code. I've removed the app and have it reinstalling now. Hopefully this will clean the issues up.
Message 10 of 10
maxim_k
For AC LT 2012 for Mac from AppStore latest version is "F.51.M.310"
You can verify it with _VERNUM command:
Command: _VERnum
_VERNUM = "F.51.M.310" (read only)
In order to reset settings to defailt you can also use "Reset application options" button on Application tab of AutoCAD LT preferences, or trash com.autodesk.autocadlt.plist file from ~/Library/Preferences folder (Library folder inside Home folder)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
