I have received a drawing from a Surveyor which has items with 3d attributes like contour lines and a tennis court set to a certain elevation. I have asked them to save it back and flatten it all to a zero elevation. They are using AutoCAD Civil 3D and have flattened it and saved it to both AutoCAD 2010 and 2007 with a visual style of 2D Wireframe. I am using AutoCAD 2014 for Mac. When I receive the files, I open both of them to the same result: They open in the 2D wire frame' visual style and everything appears flat in plan view. When I save or AutoCAD autosaves, the screen background becomes gray (from black) and the visual style turns to 'wireframe'. Some of the points and symbols become skewed or move, until I reselect '2d wireframe'. Others in my office have opened the file and when they save it, it does not change to 'wireframe' on their computers. They are also using AutoCAD 2014 for Mac.
Frustrated, please help-
JW
Solved by maxim_k. Go to Solution.
Thanks Maxim,
I went ahead and Auditted and Purged a few times and it did not change.
I have attached photos below.
Before- is when I open it and change it to 2D Wireframe and begin to work.
After-is after I save it and it reverts to Wireframe.
I appreciate the help,
JW
