AutoCAD for Mac General Discussion
davidh2
Message 31 of 60 (2,858 Views)
Re: AutoCad for Mac doesn't work on older white MacBook?
10-28-2010 01:00 PM in reply to: dgorsman
I am not Autodesk folk, but here are the reasons:
1.  New software, coded from the ground up, and written for forward moving OS (therefore 64-bit).
2.  Utilized the guidelines/restrictions that Apple put on.  No secret, you walk Apple's way, for an OSX.
3.  Comparing Photoshop, Sketchup to other software is not a good comparision.  Comparing what works through Boot Camp, etc is no a good comparision.
I agree with the people who say that the hardware requirements were stated clearly.
David Haynes
Ideate, Inc.
www.ideateinc.com
New Member
materiology
Message 32 of 60 (2,732 Views)
11-04-2010 11:32 PM in reply to: davidh2
Hi there,
I am having the same problem with running autocad for mac. Downloaded and installed it perfectly but it just won't run. The symbol starts to bounce, it starts to load and then it shuts down unexpectedly. Any workaround for this in the meantime?
I am on the student version and here are my specs:
Macbook Pro 6,2 with 2,66 GHz Intel Core i7
4GB 1067 MHz
Intel HD Graphics integrated
NVIDIA GeForce GT 330M with 512 MB VRAM
Screen resolution is 1680x1050
Thank you very much,
Alex
pheyser
Message 33 of 60 (2,726 Views)
11-04-2010 11:41 PM in reply to: materiology
I got the same problem, Student version as well.  I don't think it's an issue with hardware requirement, since it installed fine.  Plus, a person from Autodesk actually said that even though my model doesn't meet the minimum requirement, it was tested and shown to be working fine.
Perhaps it's an issue with licensing.
New Member
materiology
Message 34 of 60 (2,723 Views)
11-04-2010 11:54 PM in reply to: pheyser
I think my hardware should meet the requirements easily. It has to be something else. I'll try to run it on an older macbook pro later today.
pheyser
Message 35 of 60 (2,721 Views)
11-05-2010 12:04 AM in reply to: materiology
I think the hardware check is done during installation.  If it installs, it SHOULD run.  Emphasis on "should" since AutoCAD installed on my system but doesn't run, dock icon bounces then nothing.
Here's something I noticed that made me think it's a licensing issue, in Activity Monitor, when I started AutoCAD, two processes named "AutoCAD" and a License Management Utility (or something like that) started, then one of the AutoCAD processes quit leaving the other and the LMU one running.  I usually have to quit them manually.  Maybe it got stuck trying to get the license or something.
Active Member
MacCadder
Message 36 of 60 (2,657 Views)
11-08-2010 10:51 AM in reply to: mlynskey
I honestly feel some of the users are being a bit naive thinking it's unfair for AutoDesk not to support older hardware.  CAD software was not designed to be used on entry level or power pinching hardware, which includes 98% of all laptops, both Mac and PC, there are a lot of factors. Most professional level designers are utilizing very high end equipment, and its not uncommon for an actual CAD machine to cost well above 10K, graphics alone are 3K and up.
The hardware is just not there in the older Macbooks, I have one too and tried it, so I know first hand. I was going to try an install it on a PowerMac G5 that's just sitting here collecting dust but installed on a new Mac Pro instead and it runs really nice.
*Expert Elite*
dgorsman
Message 37 of 60 (2,647 Views)
11-08-2010 12:15 PM in reply to: MacCadder
10K, as in "ten thousand dollars"?  Thats a bit much.  I think you would be hard pressed to find a common CAD workstation above 5K and for the large muti-nationals per-workstation costs will be in the 2K region.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Member
MacCadder
Message 38 of 60 (2,637 Views)
11-08-2010 01:01 PM in reply to: davidh2
I'm talking high end CAD workstations, sure you can get in all the ranges. My MacPro was almost $5000 and its nothing special, these are CDN prices I'm referring to. NVidia's new Quattro 6000 is over 4K, itself.
I have an acquaintance who sources out these systems for companies like Daimler-Chrysler, Tool And Die Industry, and he says it's easy to spend over $10K for these systems, I too was shocked when he told me. He never mentioned whether software was included but that could be the case too, but my main point was that CAD software is a very specific piece of software intended for certain types of hardware. Some hardware will run it great, others not so great, and then finally those that are not supported.
*Expert Elite*
dgorsman
Message 39 of 60 (2,620 Views)
11-08-2010 03:47 PM in reply to: MacCadder
Somebody is earning their commision...  Yes its easy to spend lots of money when you overspec components.  A Quadro card costing over $3000 is overkill for the average CAD user.  Maybe (just maybe) if you are doing real-time fully rendered FEA analysis, movie-grade animations, or the like its necessary but a nice cheap FX1800 will do just fine for most.  Same with the processor; a $2000 Xeon processor will get the job done but a $300 i7 will do the same thing with virtually no difference.
New Member
stevejb
Message 40 of 60 (2,446 Views)
11-18-2010 01:21 PM in reply to: davidh2
Obviously it sounds like these hardware limitations are only a real problem with 3D models. I am running a macbook 2,1 with windows 7 and autocad 2010, which runs absolutely fine for 2D.
The question is, will Autodesk release Autocad LT for mac with support for older hardware?
thanks
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
