I have tried several times to download the trial version onto a brand new Mac Pro running OS X Snow Leopard. Akami downloads, then I downloaded the AutoCAD trial, then I installed the trial version. When I click on the AutoCAD icon in the dock the splash window appears saying "loading" for a few seconds, then it closes. I tried uninstalling and reinstalling, rebooting the computer, all the usual tricks. And yes, language is set to English.
From what I can tell this is a problem for a lot of people but I have seen no explanation or suggestion other than an obscure suggesting about Journalling and reformatting the harddrive. Seems a bit excessive for a 30 day trial.
Hey Autodesk, if you want to sell to Mac users I suggest you give us some help!
Solved by maxim_k. Go to Solution.
I found a suggestion in a user forum that referenced something about a "Journeling" setting. I have no idea what it means. And I don't understand what you mean by Case Sensative partition or Console app. I am not an administrator or an IT expert. I use AutoCAD as a tool, I don't write lisp routines or anything else like that so please,please, please write your replies in "Dummies For" language.
Thanks in advance for any help you can give me.
Hi Katie,
You should not be an administrator or an IT expert in order to know where Console application located.
It is very simple:
- locate Spotlight search in the upper right corner of you screen,
- put cursor there and start type word "Console":
- you will see something like this:
- select Console from list and hit Return (enter) key to start Console.app
- you will be granted with window:
- on the left Pane select "system.log" (#1 on screen-shot), if you don't see left Pane - click on "Show Log list" button on toolbar
- start AutoCAD, then look to the right Pane of Console app - you should see information about AutoCAD (in my case - AutoCAD started successfully - see #2 on the screen-shot)
- in your case you should see something different, try to select information since the time you start AutoCAD with mouse (just like you do it in your favorite text editor), then copy to clipboard and paste to your reply on Forums.
About "Journaling" and "Case Sensitive" - don't bother, as I think it's OK with your File System, as you wrote, that your Mac is "brand new".
Maxim
Thanks for the details, I was able to find just what you asked for. Below is the last few inches after I tried to launch the trial AutoCAD on my mac.
10:28:38 CUPS config timestamp change detected but old config retrieved via interface!Aug 19 10:28:47 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12082]): posix_spawn("/Library/Printers/Canon/CUPSPS2/BackGrounder/Canon PS2 BackGrounder.app/Contents/MacOS/Canon PS2 BackGrounder", ...): No such file or directoryAug 19 10:28:47 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12082]): Exited with exit code: 1Aug 19 10:28:47 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder): Throttling respawn: Will start in 10 secondsAug 19 10:28:57 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12084]): posix_spawn("/Library/Printers/Canon/CUPSPS2/BackGrounder/Canon PS2 BackGrounder.app/Contents/MacOS/Canon PS2 BackGrounder", ...): No such file or directoryAug 19 10:28:57 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12084]): Exited with exit code: 1Aug 19 10:28:57 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder): Throttling respawn: Will start in 10 secondsAug 19 10:28:57 Administrators-MacBook-3 LMU[12000]: exiting and supressing hooks: 0Aug 19 10:29:07 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12086]): posix_spawn("/Library/Printers/Canon/CUPSPS2/BackGrounder/Canon PS2 BackGrounder.app/Contents/MacOS/Canon PS2 BackGrounder", ...): No such file or directoryAug 19 10:29:07 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder[12086]): Exited with exit code: 1Aug 19 10:29:07 Administrators-MacBook-3 com.apple.launchd.peruser.502[93] (jp.co.canon.CUPSPS2.BackGrounder): Throttling respawn: Will start in 10 seconds
Yeah! it worked! Now I can try this version out. You should put this on the download page, I have been fooling around trying to download this ever since it was announced!
Thanks so much for the simple solution and explanations, it really helped. BTW, there was only one .data file in the FLEXnet folder.
hi, similar problem, cant run the trial version Autocad 2012 mac version, i read all the post and the link to solve the problem with the FLEXnet folder, dont have FLEXnet folder but some adobe programs installed, my console tells this:
29-08-11 3:50:17[0x0-0xad0ad].com.autodesk.AutoCAD[11677]Autoload Feature Installed29-08-11 3:50:17[0x0-0xad0ad].com.autodesk.AutoCAD[11677]Materials Configuration Not Found in the Bundle - Skipping 29-08-11 3:50:20lmuopen[11723]Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU29-08-11 3:50:26com.apple.launchd.peruser.501[223]([0x0-0xad0ad].com.autodesk.AutoCAD[11677]) Exited with exit code: 255
Any clue?
Where do you looking for FLEXnet folder?
You shuold look for it in the Library folder in root partition of your HD:
/Library/Preferences/FLEXnet Publisher/FLEXnet
Maxim
Cannot open AutoCAD_2012_English_Mac_OSX.dmg from desktop: Double-clicking on .dmg icon opens a window that says "WARNING The following disk images couldn't be opened" "AutoCAD_2012_English_Mac_OSX.dmg" Reason: "not recognized". However, the installer for the Akamai NetSession Interface.pkg opened and apparently achieved the download. What's happening?
The Flexnet folder is in Macintosh HD/Library/Preferences. There is also a Library folder in Username/Library/Preferences where Username is your name. You want the first one.
same problem, my splash screen wont go past the "loading" stage to allow me to register and authenticate my program. i have upgraded to Lion, as well as tried to download 2011 and 2012 multiple times. this is what my console says:
Sep 13 00:13:53 Lauren-Galeottis-MacBook-Pro [0x0-0x9d09d].com.autodesk.AutoCAD[7264]: Autoload Feature InstalledSep 13 00:13:53 Lauren-Galeottis-MacBook-Pro [0x0-0x9d09d].com.autodesk.AutoCAD[7264]: Materials Configuration Not Found in the Bundle - Skipping Sep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7308]: 7308 DAEMONIZE: setting umask 0Sep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7308]: 7308 DAEMONIZE: session parent exitingSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7308]: exiting and supressing hooks: 0Sep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7309]: 7309 DAEMONIZE: session new session leaderSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7309]: 7309 DAEMONIZE: tty disconnect parent exitingSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7310]: 7310 DAEMONIZE: tty disconnect childSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7310]: 7310 DAEMONIZE: closing file descriptorsSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7310]: 7310 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopenSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7310]: 7310 with argument: lmuopenSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro LMU[7310]: 7310 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMUSep 13 00:13:57 Lauren-Galeottis-MacBook-Pro lmuopen[7310]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMUSep 13 00:14:28 Lauren-Galeottis-MacBook-Pro com.apple.launchd.peruser.501[134] ([0x0-0x9d09d].com.autodesk.AutoCAD[7264]): Exited with code: 255
unsure what this means, please help. i need this for school and am becoming increasingly frustrated. ive been trying to get this to work for HOURS.
Hey everyone, I have exactly the same problem as the previous user. I need to use AutoCAD asap 😞 But ever since I installed MAC OS X Lion I cannot use CAD on my MacBook Pro.
The other problem I have is the link on the first page It goes to some kind of fake website that has nothing to do with the problem.
PLEASE PLEASE PLEASE HELP!!!!
Hi
The address of my blog has changed (not sure temporary or not):
so I update broken link to the solution here:
http://macacad.wordpress.com/2010/11/25/autocad-for-mac-and-adobe-software/
Maxim
For some reason board system added some garbage to the end of the link, it should ends with "software/"
Maxim
