AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD for Mac 2012 Licensing query
8 REPLIES 8
Message 1 of 9
charlv
1393 Views, 8 Replies
Hi all,
I heard a rumour that if you own AutoCAD or a Suite that contain an AutoCAD that you can install AutoCAD for Mac 2012 and have it activated. Is this true? Can someone confirm this. Here's the blog that mentions this ...http://blog.jtbworld.com/2011/08/autocad-2012-for-mac-licensing-and.html
Charl
8 REPLIES 8
Message 2 of 9
raumpunktmp
in reply to: charlv
page 5: FAQ
Message 3 of 9
TravisNave
in reply to: charlv
Yes.  That is correct.  It's no rumor.  If Jimmy posts it on his block, you can be assured that it is a fact.
Autodesk Forums:
Message 4 of 9
charlv
in reply to: TravisNave
Another Question - the document says that AutoCAD for MAc is available for Suite that has AutoCAD. Does this apply to a Suite like Product Design Suite as does not contain 'AutoCAD' but 'AutoCAD Mechanical'?
charl
Message 5 of 9
raumpunktmp
in reply to: charlv
Is it possible to activate AutoCAD 2012 for Windows with serial of AutoCAD 2012 for Mac ? Can anybody answer ? - Subscription Websupport was not able to help.
Message 6 of 9
TravisNave
in reply to: charlv
The way I understand it, the license is not platform specific.
Autodesk Forums:
Message 7 of 9
raumpunktmp
autocad 2012 for mac serial does not work in autocad 2012 for windows.
Message 8 of 9
JohnRennie
in reply to: raumpunktmp
Autodesk markets and sells them as completely different products, likely because the AutoCAD for MAC is so far behind in development terms from the PC version that they can't take direct comparison.
It means that if you use a MAC and AutoCAD for MAC at work you are unable to install a PC copy at home, if you own a PC, either under the home user scheme or by using the license tranfer utility.
Not exactly easy to live with and comes nowhere close to giving the customers what they need.
Message 9 of 9
raumpunktmp
in reply to: JohnRennie
 Autodesk FAQ for AutoCAD 2012:
3.9 Can I transfer my AutoCAD license between platforms (from AutoCAD to AutoCAD for Mac)?
Yes. Customers with licenses of AutoCAD 2012 can now activate AutoCAD 2012 for Mac with the same license number and activation code.
”Boost
