I used to have AutoCAD 2014 when I updated to the latest operating system (OS X Yosemite). However, it kept on crashing, and it was then when I found out that AutoCAD wasn't compatible with Yosemite yet. As a result, I decided to update to AutoCAD 2015 since it was compatible, but it seem to change anything since it keep on crashing. Is anyone experiencing the same issues?
Solved by Leaf.chai. Go to Solution.
Solved by drwheel. Go to Solution.
I'm sorry, i have bad news.... that solution doesn't work.... My 1910 € !!!!!! Autocad 2015 is still unstable..... and i still can't work with my 1910 € !!!!!! Autocad 2015. So please, Autodesk, fix it quicky or i'm going to make a formal claim with my lawyer!!!!!
I have the same problem too and threatening will not solve anything. I don't know what it is you use Autocad for, but I'm pretty sure that if you were a good architect or engineer (if that is what you do) you would always have a backup plan.
I had the same problem with Autocad 2015 and Yosemite, i've an intel 3000 graphic card on my 13" mac book pro. Today i've probably found a solution to this problem. I've activated Open GL Core Profiles in preferences --> General, after that my Autocad doesn't crash for 30 minutes. I hope that this is a real solution and not a coincidence 😃
Updating OS X does not solve the problem. Activated OpenGL Core Profile solve the problem. Thank you !! 🙂
Hi keigo
Autodesk noticed this issue happens in open file panel. After research we identified this is a Yosemite OS defect, and reported to Apple. This defect is about show open panel with “as Columns” style application will random crash. Not only happens in AutoCAD, it happens in other application as well. Please try to update Yosemite to 10.10.1 This issue would go. Before you upgrade the OS X, you could find a workaround described in this page: http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
Jian An
@keigo wrote:
Both Autocad lt 2014 and 2015crashes everyother xref (first one works second fails) I try to relink or add a xref file.
This makes the program completely useless.
Please help
Updated to OSX 10.10.1 and the crashing seems to have been resolved... but I'm not getting to comfortable just yet.
Note: This is without any work arounds that people have been posting
Dear all
10.10.1 does not resolve the crash... its happening even after updating yosemite latest 10.10.1 update and it happens preciecly every after 2 hours of opening and working on the drgs...
Thank you for sending your error report CER_104723740 to Autodesk.
this is the latest CER my computer has sent to autodesk.
autodesk pls let us know the solution to it????????????????
thanks
sumeet
india
Did the last update of the software and activated openGL but still continues to crash!
Another thing that is happening with my AutoCad is that in order for a command to function properly i need to enter the command and then select objects,it doesnt let me do it the other way around.
Any help?
Hi!!! im having the same problem i would like to know how did you do to upgrade or active the Open Gl profile on you Mac.
Thanks!!!
Thank you!
Also, the crashing problem seems fixed by activating the OpenGL Core. I believe the reason this is happening is that OS X Yosemite is consuming too much ram, but well that's just my theory.
