I used to have AutoCAD 2014 when I updated to the latest operating system (OS X Yosemite). However, it kept on crashing, and it was then when I found out that AutoCAD wasn't compatible with Yosemite yet. As a result, I decided to update to AutoCAD 2015 since it was compatible, but it seem to change anything since it keep on crashing. Is anyone experiencing the same issues?
Solved by Leaf.chai. Go to Solution.
Solved by drwheel. Go to Solution.
please!! I need to know when this problem is going to be fixed!!! autocad 2015 for MAC (yosemite) crashes every 10-15 minutes!! I only use 2d autocad, but I work with it all day, I cant work like this and I cant go back to the previous operating system
I have been hesitatnt in upgrading the OS, but did so. I have not had any issues, but it may be file related.
If you have a file or a sequence of commands that you would like me to verify or confirm let me know.
MBP Early 2011, 8G.
I couldnt get a video just a screenshoot. Hope this has some relevant information
I am getting multiple crashes since the update no warnings, only 2d files.. Today 4 times. Why Autocad WHYYYY??????????
If you include the zip it generated, maybe.
Be sure to add your email to the CER so they can contact you.
Without a file and potential cause (what you may have done prior to the crash) it's hard to say.
Hi cvillagran,
The screenshots do not tell more, did you send that crash report and do you have the ID like CER_xxxxxxxx?
And for users who see several crashes in a day during editing a file, please check if your graphics card is only Intel HD 3000? As of we know this graphics card is not working well on AutoCAD on Yosemite. We are suspecting that it is due to driver issue, basing on the info in the crash log. We have logged bug to Apple, and meanwhile we are trying to see if we can have a workaround on AutoCAD. I hope this explains the situation why some users see frequent crashes and others do not.
Wei
Also now experiencing this issue.
Installed AutoCAD 2015 Student Edition on my Macbook Pro and it crashes randomly after about 10-15 minutes of working. Makes it frustrating to use having to save after every couple minutes because of crashes.
System:
OS X Yosemite
Macbook Pro Late 2011 13" 2.8Ghz i7
256GB SSD (AutoCAD is installed on this drive)
1TB HDD
16GB RAM
yes, so I have an INTEL hd graphics 3000 and?...does this mean it wont work at all anymore? what should I do? can I go back to the 2014 version or this wont work either? I seriously need an answer please.. 😞
thanks
@larily80 wrote:
yes, so I have an INTEL hd graphics 3000 and?...does this mean it wont work at all anymore? ... I seriously need an answer please.. 😞
thanks
The clear answer from Wei was:
"We have logged bug to Apple, and meanwhile we are trying to see if we can have a workaround on AutoCAD."
The bug is on Apple side plus AutoCAD developers are working on workaround while they wait for Apple to "repair" this bug.
Maxim
hi same problem with me crashes, macbook pro 8 gb ram i 5 processor 2.3 Ghz intel HD graphics 3000
crashes while working on drg, tried different type of drgs. so not able to work on drgs ,... autocad 2015 for mac working on 2D simple drg.....able to produce exac steps... sening reports after crashing....using draft sight works fine on it....
sumeet saxena india
Hi cvillagran,
Thanks for the Report ID. From the report i can see that your GS card is the Intel HD Graphics 3000, it is the same issue i mentioned above. Sorry we do not have workaround for now.
Wei
Hi Sumeet,
Could you please send a crash report and let me know the report ID, like CER_xxxxxxx?
And if you have stable steps to reproduce the crash, could you please note here, step by step?
Wei
As of we know for now, either downgrade to Mavericks or use AutoCAD 2014 on Yosemte will not hit this issue.
Wei
can autocad or Apple resolve this problem asap? i have tried using acad 2013, 2014, 2015 and all clashed within 10 - 15 min. i have deadlines and it create quite a lot of damage to my work because of this issue. who said 2014 is not affected? 2014 also have this problme. Hurry up and get this resolved the bug. there are a lot of people getting affected.
