Basically what it says, AutoCAD 2014 is not opening on my computer. When I pull up the Activity Monitor, it says that AutoCAD is not responding (and it gets stuck there) and that the License Management is using almost 40% of my CPU.
Someone please help me I need it to work.
Welcome to the Autodesk Forums!
I think you need to try to reset AutoCAD license, look here for the details (it is about LT, but the same applies to full version):
Than you may also need to reset AutoCAD:
For AutoCAD 2014 for Mac SP1 and newer, hold down the Shift key while launching AutoCAD from Dock - press Sift key, click on AutoCAD icon in Dock than release Shift key after a few seconds. You may need to install SP1 for AC 2014 if you if you have not done this before.
Maxim
