Hi!
Hope somebody can helpme with this. I just go updated to Mavericks and Autocad 2014, but I have a problem, I can't plot any layouts!
When I hit plot the print window opens, then i can choose printer and plot styles very well. But, when I choose print just doesn't work 😞 The window dissappear and nothing happens.
It's the same if I choose Open PDF in preview or save to PDF, just doesn't work.
Please help!
Many thank's!
I have the following problem:
I can print layouts without any problem if I print each of them from their layout tab. I have setup
a custom paper size and it works fine.
Once I batch print multiple layouts the result is shifted in the pdf and a part is cut off. I´m using the same page setup like I
do for the single page print.
Any suggestions? It´s a little annoying because I have lots of layouts to print and I would now have to print
each of them manually.
thanks in advance...
Thank you for your answer.
It doesn´t matter if I print single or multiple pdf. it´s always shifted. printing manually each page works fine.
I even set up a new page setup and have still the same problem.
I found a work around:
I made a new custom papersize and used that in a new page setup. then I applied that page setup to all layouts in the batch plot dialog and it works.
wierd because my other paper size always worked perfectly...
thank you for your help!
I also have a layout plotting issue with my Mac AC2014 running on my MacBook Pro with 10.10.1 (yosemite).
When I attempt to plot a layout (what to print: layout) and then hit preview, it shows only a small piece of my drawing, so EVERY time I have to do window and grab the view I want.
The second issue seems more glitchy than anything. When I select my paper size, I pick ANSI D which I had to put in as a custom size. For orientation I choose landscape and it never switches it to landscape, always stays in portrait.
Sorry to throw 2 issues at you at once but they seem conneted possibly.
I tried creating a fresh page setup and no change. I will admit that I am new to the mac version of autocad LT. I used 2008 LT on a PC for years and the plotting process is totally different on the mac.
I attached some photos of my screen as I attempt to navigate through the plot process. I use a company printer that is on a server in our office, and I am attached via ethernet. Do I need the drivers like the warning message says even though I have no issue using this printer for normal use (non cad)?
When you open Print dialog or Page Setuo dialog for the first time on your Mac, you should not worry about the alert as it only indicates that current page setup saved in the drawing is using this ("DWG to PDF.pc3") plotter configuration. I can say that this plotter configuration was created in PC version of AutoCAD and includes information about "DWG to PDF" plot device available in each AutoCAD for PC version. But you haven't such plotter on your Mac (of course).
In order to be able to plot (save to PDF) from AutoCAD on your Mac you need to create named Page Setup for the printer (plotter) available on your Mac - it could be a company printer attached via Network and configured for using on your Mac, i.e. it should be listed in "Printers & Scanners" pane of Mac OS System Preferences you should be able to use this printer in all applications on Mac.
Than you open your drawing in AutoCAD, switch to Layout, use menu File -> Page Setup Manager to open Page Setup Manager window:
Select current Named Page setup in the list of Page Setups (it is marked with triangle) and click on "+" button, give it a name and select Continue:
Now you most likely will get an alert about "DWG to PDF.pc3" - just ignore it now and hot OK. This will bring you to Page Setup window and AutoCAD will set your current Mac OS system printer as printer for this page setup, the paper size and orientation will match the default settings in your system. Now you have to make settings for Paper size and orientation you want to use in this Page setup and other settings you need (What to print, etc.)
Now click on OK
This will bring you back to Page setup manager where you should select Page setup you just created and set it current:
Now close Page setup manager - you are ready to print the Layout from your Mac via Print dialog - as soon as you will open it you will see all settings you saved for this Layout in named page setup:
One caution: if you are using Custom Paper size and System printer already have default paper size the same size as you have in your Custom paper size (for example you changed print margins in your custom paper size) AutoCAD will substitute your Custom paper size in Print dialog each time when you start to print using Print command and you need to verify this before you start to print - this is a bug in AutoCAD for Mac under Mavericks and Yosemite.
Maxim
Alright, I setup a new page setup, named it "508" and on my system preferences I named my server printer "CORRTECH 1"
I tried to follow your steps but I still can't get the layout to work, see my attached photo of my preview. To be honest at first everything seemed very buggy. I have installed the service packs but I still have weird issues like this, and its hard for me to determine if issuse I still have are bugs or if I am doing something incorrectly.
"508" was setup using a custom paper size that I put in there, ANSI D landscape which is 34" x 22"
I selected my custom paper size and set current, also changed print preset to defalt....still wilnot capture my layout properly
I really appreciate your time helping me through this. Please pardon my frustration as I have multiple drawing sets that I need to get out the door each day. The plotting process currently takes me FAR to long and I am hoping that eventually everything will run smoothly.
Any idea if there will be more service packs for the AC LT 2014 for mac using yosemite? There are several other issues that I come across daily that I just deal with hoping that they will be fixed soon.
It seems to me you need to change your Custom paper side settings.
On your screenshot I can see:
Custom paper size "ANSI D Landscape" is 34.00 by 22.00 inches, but you need to set it to 22.00 by 34.00 inches:
And leave orientation in Page setup as you set it (landscape):
Now try to print (preview) your drawing.
Maxim
