AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2014 LT for Mac does not open with OS X 10.9.3
12 REPLIES 12
Message 1 of 13
2445 Views, 12 Replies
I have purchased AutoCad LT 2014 for Mac to be used on my iMac with 2.7 GHz Intel Core i5 processor and OS X 10.9.3.
It downloaded and installed successfully, but when I click on the application, the opening window appears with the red and grey AutoCad graphic, the "loading..." script shows, but after a few seconds, the window disappears. I've tried uninstalling with the preferences removed and then reinstalling and it still does the same thing.
I've tested out AutoCad 2014 on a trial and it works but I purchased AutoCad LT 2014!  How do I get it to work?  Any help out there?
HParchitect
12 REPLIES 12
Message 2 of 13
maxim_k
Welcome to the Autodesk Forums!
Could you provide information from System.log (use Console application) at the moment when you are launching AutoCAD LT?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 13
in reply to: maxim_k
I just tried uninstalling and reinstalling again.  Here is a my System Log:
Jun 4 23:12:36 --- last message repeated 1 time ---
Jun 4 23:12:36 imac2012 kernel[0]: hfs: mounted Autodesk AutoCAD LT 2014 for Mac Installation on device disk1s1
Jun 4 23:12:36 imac2012.local mds[40]: (Normal) Volume: volume:0x7f92a381f800 ********** Bootstrapped Creating a default store:1 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/Autodesk AutoCAD LT 2014 for Mac Installation
Jun 4 23:12:36 imac2012.local backupd[209]: Property list invalid for format: 200 (property lists cannot contain NULL)
Jun 4 23:12:37 imac2012.local DiskImages UI Agent[304]: *** -[NSMachPort handlePortMessage:]: dropping incoming DO message because the connection is invalid
Jun 4 23:12:46 imac2012.local com.apple.InputMethodKit.UserDictionary[358]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](760): CoreData: Ubiquity: ianboyle~487DA01A-0BB6-5791-BD7C-BFB1EB38CF78:UserDictionary
Using local storage: 1
Jun 4 23:12:50 imac2012.local WindowServer[88]: disable_update_timeout: UI updates were forcibly disabled by application "Installer" for over 1.00 seconds. Server has re-enabled them.
Jun 4 23:12:50 imac2012.local com.apple.InputMethodKit.UserDictionary[358]: -[PFUbiquitySwitchboardEntryMetadata setUseLocalStorage:](760): CoreData: Ubiquity: ianboyle~487DA01A-0BB6-5791-BD7C-BFB1EB38CF78:UserDictionary
Using local storage: 0
Jun 4 23:12:51 imac2012.local WindowServer[88]: common_reenable_update: UI updates were finally reenabled by application "Installer" after 2.79 seconds (server forcibly re-enabled them after 1.00 seconds)
Jun 4 23:12:57 imac2012.local com.apple.SecurityServer[15]: Session 100013 created
Jun 4 23:13:45 imac2012.local launchservicesd[58]: Application App:"Installer" asn:0x0-25025 pid:314 refs=7 @ 0x7faa58f5b5a0 tried to be brought forward, but isn't in fPermittedFrontApps ( ( "LSApplication:0x0-0x27027 pid=375 "SecurityAgent"")), so denying. : LASSession.cp #1481 SetFrontApplication() q=LSSession 100004/0x186a4 queue
Jun 4 23:13:45 imac2012.local WindowServer[88]: [cps/setfront] Failed setting the front application to Installer, psn 0x0-0x25025, securitySessionID=0x186a4, err=-13066
Jun 4 23:14:21 imac2012.local backupd[209]: Property list invalid for format: 200 (property lists cannot contain NULL)
Jun 4 23:14:23 imac2012.local sudo[385]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=root ; COMMAND=/bin/chmod a+rwx /Library/Application Support/Autodesk/ADLM/.config/
Jun 4 23:14:23 imac2012.local sudo[387]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=root ; COMMAND=/bin/chmod a+rwx /Library/Application Support/Autodesk/ADLM
Jun 4 23:14:23 imac2012.local sudo[392]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=ianboyle ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister -kill -domain local -domain system -domain user
Jun 4 23:14:40 imac2012.local mds[40]: (Normal) Volume: volume:0x7f92a401aa00 ********** Bootstrapped Creating a default store:0 SpotLoc:(null) SpotVerLoc:(null) occlude:0 /Volumes/firmwaresyncd.4bWfI4
Jun 4 23:14:40 imac2012.local backupd[209]: Property list invalid for format: 200 (property lists cannot contain NULL)
Jun 4 23:14:54 imac2012.local sudo[416]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=ianboyle ; COMMAND=/System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/Support/lsregister -f -r /Applications/Autodesk/AutoCAD LT 2014/AutoCAD Plot Style Editor 2014.app
Jun 4 23:14:54 imac2012.local sudo[423]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=root ; COMMAND=/usr/sbin/chown -R ianboyle:staff /Applications/Autodesk/AutoCAD LT 2014
Jun 4 23:14:56 imac2012.local sudo[425]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.M7bNdi ; USER=root ; COMMAND=/bin/chmod -R 755 /Applications/Autodesk/AutoCAD LT 2014
Jun 4 23:14:57 imac2012.local osascript[430]: Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: no matching architecture in universal wrapper
Jun 4 23:14:58 imac2012.local System Events[431]: .sdef warning for part of complex type 'any | number | boolean | date | list | record | text | data' used in suite 'Property List Suite': 'data' is not a valid type name.
Jun 4 23:14:58 imac2012.local System Events[431]: .sdef warning for type 'text | missing value | any' attribute 'uniqueID' of class 'XML element' in suite 'XML Suite': AppleScript ID references may not work for this property because its type is not NSNumber- or NSString-derived.
Jun 4 23:14:59 imac2012.local osascript[472]: Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
Jun 4 23:14:59 imac2012.local osascript[483]: Error loading /Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types: dlopen(/Library/ScriptingAdditions/Adobe Unit Types.osax/Contents/MacOS/Adobe Unit Types, 262): no suitable image found. Did find:
Jun 4 23:15:00 imac2012.local postflight[523]: bundle path is "/Applications/Autodesk/AutoCAD LT 2014"
Jun 4 23:15:00 imac2012.local sudo[525]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.registerproduct.pkg.1TFEHE ; USER=root ; COMMAND=/usr/sbin/chown -R ianboyle:staff /Applications/Autodesk/AutoCAD LT 2014/License Transfer Utility
Jun 4 23:15:00 imac2012.local sudo[527]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.registerproduct.pkg.1TFEHE ; USER=root ; COMMAND=/bin/chmod -R 755 /Applications/Autodesk/AutoCAD LT 2014/License Transfer Utility
Jun 4 23:15:00 imac2012.local sudo[536]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.dockicon.pkg.zHqvc8 ; USER=ianboyle ; COMMAND=/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.dockicon.pkg.zHqvc8/DockIconInstaller /private/tmp/PKInstallSandbox.LtCvTk/tmp/_acinst_loc
Jun 4 23:15:00 imac2012.local sudo[540]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.lib.pkg.0pknQx ; USER=root ; COMMAND=/usr/sbin/chown -R ianboyle:staff /Library/Application Support/Autodesk/Adlm/ASR/ACDLTM
Jun 4 23:15:00 imac2012.local sudo[542]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.lib.pkg.0pknQx ; USER=root ; COMMAND=/bin/chmod -R ug+rx /Library/Application Support/Autodesk/Adlm/ASR/ACDLTM
Jun 4 23:15:00 imac2012.local sudo[544]: root : TTY=unknown ; PWD=/private/tmp/PKInstallSandbox.LtCvTk/Scripts/com.autodesk.autocadlt2014.lib.pkg.0pknQx ; USER=root ; COMMAND=/bin/chmod -R o+rx /Library/Application Support/Autodesk/Adlm/ASR/ACDLTM
Jun 4 23:15:01 imac2012.local NotificationCenter[199]: Connection interrupted.
Jun 4 23:15:01 imac2012 com.apple.launchd.peruser.503[152] (com.apple.Dock.agent[169]): Exited with code: 1
Jun 4 23:15:01 imac2012.local com.apple.time[157]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Jun 4 23:15:02 imac2012.local soagent[561]: No active accounts, killing soagent in 10 seconds
Jun 4 23:15:02 imac2012.local backupd[209]: Property list invalid for format: 200 (property lists cannot contain NULL)
Jun 4 23:15:02 imac2012.local com.apple.dock.extra[559]: No endpoint returned trying to load UnreadCountController.bundle, suspending
Jun 4 23:15:12 --- last message repeated 1 time ---
Jun 4 23:15:12 imac2012.local soagent[561]: Killing soagent.
Jun 4 23:15:12 imac2012.local com.apple.dock.extra[559]: SOHelperCenter main connection interrupted
Jun 4 23:15:12 imac2012.local imagent[206]: [Warning] Denying xpc connection, task does not have entitlement: com.apple.private.icfcallserver (soagent:561)
Jun 4 23:15:26 --- last message repeated 1 time ---
Jun 4 23:15:26 imac2012 kernel[0]: hfs: unmount initiated on Autodesk AutoCAD LT 2014 for Mac Installation on device disk1s1
Jun 4 23:18:02 imac2012.local Console[851]: setPresentationOptions called with NSApplicationPresentationFullScreen when there is no visible fullscreen window; this call will be ignored.
Jun 4 23:19:25 imac2012.local Autodesk 360[867]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N8Autodesk11WebServices20IWebServicesObserverE, 18SyncServiceManager, N8Autodesk11WebServices27IWebServicesObserverPrivateE.
Jun 4 23:19:25 imac2012.local Autodesk 360[867]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N8Autodesk11WebServices20IWebServicesObserverE, 23WebServicesUIManagerImp, N8Autodesk11WebServices27IWebServicesObserverPrivateE.
Jun 4 23:19:32 imac2012.local Autodesk 360[867]: CoreText performance note: Client called CTFontCreateWithName() using name "Times New Roman" and got font with PostScript name "TimesNewRomanPSMT". For best performance, only use PostScript names when calling this API.
Jun 4 23:19:32 imac2012.local Autodesk 360[867]: CoreText performance note: Set a breakpoint on CTFontLogSuboptimalRequest to debug.
Jun 4 23:19:33 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/DirectorShockwave.plugin/Contents/MacOS/DirectorShockwave: dlopen(/Library/Internet Plug-Ins/DirectorShockwave.plugin/Contents/MacOS/DirectorShockwave, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/DirectorShockwave.plugin/Contents/MacOS/DirectorShockwave: no matching architecture in universal wrapper
Jun 4 23:19:33 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/AdobePDFViewer.plugin/Contents/MacOS/AdobePDFViewer: dlopen(/Library/Internet Plug-Ins/AdobePDFViewer.plugin/Contents/MacOS/AdobePDFViewer, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/AdobePDFViewer.plugin/Contents/MacOS/AdobePDFViewer: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/EPPEX Plugin.plugin/Contents/MacOS/EPPEX Plugin: dlopen(/Library/Internet Plug-Ins/EPPEX Plugin.plugin/Contents/MacOS/EPPEX Plugin, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/EPPEX Plugin.plugin/Contents/MacOS/EPPEX Plugin: mach-o, but wrong architecture
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/Flip4Mac WMV Plugin.webplugin/Contents/MacOS/Flip4Mac WMV Plugin: dlopen(/Library/Internet Plug-Ins/Flip4Mac WMV Plugin.webplugin/Contents/MacOS/Flip4Mac WMV Plugin, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/Flip4Mac WMV Plugin.webplugin/Contents/MacOS/Flip4Mac WMV Plugin: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/Silverlight.plugin/Contents/MacOS/agcore: dlopen(/Library/Internet Plug-Ins/Silverlight.plugin/Contents/MacOS/agcore, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/Silverlight.plugin/Contents/MacOS/agcore: mach-o, but wrong architecture
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/Flip4Mac WMV Plugin.plugin/Contents/MacOS/Flip4Mac WMV Plugin: dlopen(/Library/Internet Plug-Ins/Flip4Mac WMV Plugin.plugin/Contents/MacOS/Flip4Mac WMV Plugin, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/Flip4Mac WMV Plugin.plugin/Contents/MacOS/Flip4Mac WMV Plugin: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/QuickTime Plugin.plugin/Contents/MacOS/QuickTime Plugin: dlopen(/Library/Internet Plug-Ins/QuickTime Plugin.plugin/Contents/MacOS/QuickTime Plugin, 265): no suitable image found. Did find:
/Library/Internet Plug-Ins/QuickTime Plugin.plugin/Contents/MacOS/QuickTime Plugin: mach-o, but wrong architecture
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/OfficeLiveBrowserPlugin.plugin/Contents/MacOS/OfficeLiveBrowserPlugin: dlopen(/Library/Internet Plug-Ins/OfficeLiveBrowserPlugin.plugin/Contents/MacOS/OfficeLiveBrowserPlugin, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/OfficeLiveBrowserPlugin.plugin/Contents/MacOS/OfficeLiveBrowserPlugin: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/DivXBrowserPlugin.plugin/Contents/MacOS/DivXBrowserPlugin: dlopen(/Library/Internet Plug-Ins/DivXBrowserPlugin.plugin/Contents/MacOS/DivXBrowserPlugin, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/DivXBrowserPlugin.plugin/Contents/MacOS/DivXBrowserPlugin: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Error loading /Library/Internet Plug-Ins/iPhotoPhotocast.plugin/Contents/MacOS/iPhotoPhotocast: dlopen(/Library/Internet Plug-Ins/iPhotoPhotocast.plugin/Contents/MacOS/iPhotoPhotocast, 262): no suitable image found. Did find:
/Library/Internet Plug-Ins/iPhotoPhotocast.plugin/Contents/MacOS/iPhotoPhotocast: no matching architecture in universal wrapper
Jun 4 23:19:34 imac2012.local Autodesk 360[867]: Cannot find executable for CFBundle 0x7f923ac630d0 </Library/Internet Plug-Ins/Disabled Plug-Ins> (not loaded)
Jun 4 23:19:54 imac2012.local Autodesk 360[867]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N8Autodesk11WebServices20IWebServicesObserverE, 23SyncWebServicesObserver, N8Autodesk11WebServices27IWebServicesObserverPrivateE.
Jun 4 23:19:54 imac2012.local Autodesk 360[867]: dynamic_cast error 2: One or more of the following type_info's has hidden visibility. They should all have public visibility. N8Autodesk11WebServices20IWebServicesObserverE, 18SyncServiceManager, N8Autodesk11WebServices27IWebServicesObserverPrivateE.
Jun 4 23:19:54 imac2012.local Autodesk 360[867]: modalSession has been exited prematurely - check for a reentrant call to endModalSession:
Jun 4 23:19:54 imac2012.local Autodesk 360[867]: CoreText performance note: Client called CTFontCreateWithName() using name "Arial" and got font with PostScript name "ArialMT". For best performance, only use PostScript names when calling this API.
Jun 4 23:20:09 --- last message repeated 4 times ---
Jun 4 23:20:09 imac2012.local mdworker[873]: Error loading /Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/Contents/MacOS/AcSpotlight: dlopen(/Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/Contents/MacOS/AcSpotlight, 262): Library not loaded: @rpath/libWinAPI.dylib
Referenced from: /Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/Contents/MacOS/AcSpotlight
Reason: image not found
Jun 4 23:20:09 imac2012.local mdworker[873]: Cannot find function pointer MetadataImporterPluginFactory for factory 0AB6CD54-270B-47F4-8020-BED07EC5ECA1 in CFBundle/CFPlugIn 0x7fc273d23060 </Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter> (bundle, not loaded)
Jun 4 23:20:09 imac2012.local mdworker[873]: (Error) Import: Could not create instance for plugIn 'file:///Applications/Autodesk/AutoCAD%20LT%202014/AutoCAD%20LT%202014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/'
Jun 4 23:20:09 imac2012.local mdworker[873]: (Error) Import: BAD IMPORTER ~~~~~~~~~~~~~~~~~~ file:///Applications/Autodesk/AutoCAD%20LT%202014/AutoCAD%20LT%202014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/
Jun 4 23:20:52 imac2012.local Console[879]: setPresentationOptions called with NSApplicationPresentationFullScreen when there is no visible fullscreen window; this call will be ignored.
Message 4 of 13
maxim_k
Please - without installation: only from the moment when you click on AutoCAD icon in the Dock (and, please, restart your Mac before you will try to launch AutoCAD)
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 13
Here is it again as you requested:
Jun 5 08:34:29 --- last message repeated 2 times ---
Jun 5 08:34:29 imac2012.local mdworker[358]: Error loading /Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/Contents/MacOS/AcSpotlight: dlopen(/Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/Contents/MacOS/AcSpotlight, 262): Library not loaded: @rpath/libWinAPI.dylib
Jun 5 08:34:29 imac2012.local mdworker[358]: Cannot find function pointer MetadataImporterPluginFactory for factory 0AB6CD54-270B-47F4-8020-BED07EC5ECA1 in CFBundle/CFPlugIn 0x7f8b58e01fd0 </Applications/Autodesk/AutoCAD LT 2014/AutoCAD LT 2014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter> (bundle, not loaded)
Jun 5 08:34:29 imac2012.local mdworker[358]: (Error) Import: Could not create instance for plugIn 'file:///Applications/Autodesk/AutoCAD%20LT%202014/AutoCAD%20LT%202014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/'
Jun 5 08:34:29 imac2012.local mdworker[358]: (Error) Import: BAD IMPORTER ~~~~~~~~~~~~~~~~~~ file:///Applications/Autodesk/AutoCAD%20LT%202014/AutoCAD%20LT%202014.app/Contents/Library/Spotlight/AcSpotlight.mdimporter/
Jun 5 08:34:50 imac2012 com.apple.preference.datetime.remoteservice[365]: assertion failed: 13D65: liblaunch.dylib + 25164 [38D1AB2C-A476-385F-8EA8-7AB604CA1F89]: 0x25
Jun 5 08:34:50 --- last message repeated 1 time ---
Jun 5 08:34:50 imac2012.local com.apple.preference.datetime.remoteservice[365]: ### Attempt to call communicate with writeconfig before it's unlocked!
Jun 5 08:34:50 imac2012.local com.apple.preference.datetime.remoteservice[365]: Bogus event received by listener connection:
<error: 0x7fff757cbb50> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff757cbe60> { length = 18, contents = "Connection invalid" }
Jun 5 08:34:51 imac2012.local ntpd[368]: proto: precision = 1.000 usec
Jun 5 08:34:51 imac2012.local com.apple.time[151]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Jun 5 08:34:52 --- last message repeated 1 time ---
Jun 5 08:34:52 imac2012.local com.apple.preference.datetime.remoteservice[365]: Couldn't contact spell checker for U.S. English
Jun 5 08:34:55 imac2012.local com.apple.SecurityServer[14]: Session 100009 created
Jun 5 08:35:03 imac2012.local ntpd[374]: proto: precision = 1.000 usec
Jun 5 08:35:03 imac2012.local com.apple.time[151]: Interval maximum value is 946100000 seconds (specified value: 9223372036854775807).
Jun 5 08:35:33 --- last message repeated 1 time ---
Message 6 of 13
maxim_k
Could you try the solution from this post:
http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/Cannot-open-AutoCAD-LT-2013-on-brand-new-Mac/m...
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 13
Tried but the FLEXnet Publisher folder does not exist in the Library/Preferences.  No change.
Message 8 of 13
maxim_k
Without this folder and it's contents (license information) you couldn't use AutoCAD.
Have you passed Activation?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 13
I have the AutoCad Lt installed and running on my MacBook Air laptop.  Activation was completed on that computer and this folder doesn't exist on the MacBook Air.
When I installed the AutoCad LT onto my iMac, it accepts the serial and product key but because I can't start the application.  I don't know if activation was completed for the iMac.
Message 10 of 13
maxim_k
You probably have AC LT 2013 from Mac App Store on Mac Book Air? Than it licenses in different way.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 11 of 13
It is the same software I bought 1 week ago from the Autodesk online store on May 28.  It runs and says AutoCad LT 2014.  Anyway, the Laptop works but the iMac doesn't work for the exact same software download, serial number and product key.  The laptop does not have a FLEXnet publisher folder either but it runs.
The iMac was restored from a Time Machine back up, is this a problem?  It was restored and then I downloaded and installed AutoCAD LT for Mac 2014, same as the laptop but it won't run.
I can't seem to take any of the online forum advice because the FLEXnet publisher folder can not be found.
Message 12 of 13
Sorry my bad. Found the folder under root HD. I was looking under user. I'll try what you suggested earlier with renaming the folder...
Message 13 of 13
It worked! Thank you very much Maxim! I followed your suggestion on: http://forums.autodesk.com/t5/AutoCAD-for-Mac-General/Cannot-open-AutoCAD-LT-2013-on-brand-new-Mac/m...
I also installed the Service Packs 1 & 2 for AutoCadLT 2014 just in case.
”Boost
