Since i upgraded to OSX 10.9.1 my autocad 2014 for Mac ( student version ) does not startup anymore. SP1 for mac does not solve the problem. Reinstallation does not solve the problem.
Any suggestions?
HELP!!
Solved by maxim_k. Go to Solution.
Maxim,
your solution is correct! when you remove the preferences when uninstalling, you kan reinstall and the problem is solved!!
Thank you!
Welcome to the Autodesk Forums!
Even without SP1 (which is still in Beta) you can try to solve the problem by deleting (trashing) AutoCAD preferences file.
Look for it in:
~/Library/Application Support/Autodesk/local/AutoCAD 2014/R19.1/enu/
The name of the file is HKCU.plist
Quit AutoCAD (you can even restart your Mac), then navigate to the folder I mentioned above (Library folder inside your Home folder) and trash HKCU.plist file. Then try to launch AutoCAD.
Let me know about results.
Maxim
