AutoCAD for Mac General Discussion
Member
vivianisimona
Message 1 of 9 (5,405 Views)
AutoCad 2013: Print a EPS file
5405 Views, 8 Replies
04-02-2013 11:55 AM
I switched to mac recently and I can not print in eps file as before I was on winows.
How do I ad a virtual plotter?
In windows I added the printer from "plotter manager" and than I chose the "PostScript Level 1 Plus"
but now I I do not know what should I do.
*Expert Elite*
maxim_k
Message 2 of 9 (5,400 Views)
Re: AutoCad 2013: Print a EPS file
04-02-2013 12:24 PM in reply to: vivianisimona
Try "Save as PostScript..." from PDF button on AutoCAD Print dialog:
Maxim
Architect
MARSS
MacACAD | MARSS
Member
vivianisimona
Message 3 of 9 (5,396 Views)
04-02-2013 12:35 PM in reply to: maxim_k
I try to do this but I can`t chose the drawing scale, the paper size and the area of the screen that I want to print.
I also tried to "export" in eps, but the result is the same!!
Thanks :smileyhappy:
*Expert Elite*
maxim_k
Message 4 of 9 (5,391 Views)
04-02-2013 12:54 PM in reply to: vivianisimona
When I "Save as PS" from AutoCAD's Print dialog I get PS file exactly the same size and scale as PDF, I just checked in Illustrator. So everything (paper size and drawing scale) could be assigned for PS file as for PDF.
Maxim
Architect
MARSS
MacACAD | MARSS
New Member
yu.becca
Message 5 of 9 (5,361 Views)
04-09-2013 08:30 AM in reply to: vivianisimona
Hi, I'm having the same problem.  I can save as PDF in the correct size, however, when I use the same settings to save as Postscript, it only saves it as an 8.5 x 11 page.  What am I missing?
Member
vivianisimona
Message 6 of 9 (5,356 Views)
04-09-2013 09:32 AM in reply to: yu.becca
I finally discovered a way out!
Instead of printing from the window Model, I "print" after setting (from the layout windows) paper size and drawing scale.
From "Model" I could not be able to print in eps.
I hope I was helpful,
sorry for my English!! :smileywink:
*Expert Elite*
maxim_k
Message 7 of 9 (5,354 Views)
04-09-2013 09:52 AM in reply to: yu.becca
I do nothing special:
- create Page Setup via Page Setup manager,
- assign this page setup to Layout (or Model)
- in Print dialog select "Save as PostScript"
I have checked via Inkscape - page size ia absolutely the same as in PDF file created from my drawing:
Maxim
Architect
MARSS
MacACAD | MARSS
Member
kecix3c
Message 8 of 9 (4,668 Views)
08-12-2013 02:48 AM in reply to: vivianisimona
I am trying to plot the drawing to jpeg. using save as post script. i already set all the printable area and also the paper size. once im done, when i save the file. it doesnt print the priintable area. (see attachment)
is there any solution for this ? im am new in autocad mac.
*Expert Elite*
maxim_k
Message 9 of 9 (4,659 Views)
08-12-2013 03:15 AM in reply to: kecix3c
Welcome to the Autodesk Forums!
If the scale of printed output doesn't matter for you, then set Paper orientation to Landscape (because you set printing area as landscape) and check-mark "Fit to paper":
Maxim
Architect
MARSS
MacACAD | MARSS
Need installation help?
