AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCad 2013: Print a EPS file
8 REPLIES 8
Message 1 of 9
vivianisimona
14177 Views, 8 Replies
I switched to mac recently and I can not print in eps file as before I was on winows.
How do I ad a virtual plotter?
In windows I added the printer from "plotter manager" and than I chose the "PostScript Level 1 Plus"
but now I I do not know what should I do.
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: vivianisimona
Try "Save as PostScript..." from PDF button on AutoCAD Print dialog:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
vivianisimona
in reply to: maxim_k
I try to do this but I can`t chose the drawing scale, the paper size and the area of the screen that I want to print.
I also tried to "export" in eps, but the result is the same!!
Thanks Smiley Happy
Message 4 of 9
maxim_k
When I "Save as PS" from AutoCAD's Print dialog I get PS file exactly the same size and scale as PDF, I just checked in Illustrator. So everything (paper size and drawing scale) could be assigned for PS file as for PDF.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
yu.becca
Hi, I'm having the same problem.  I can save as PDF in the correct size, however, when I use the same settings to save as Postscript, it only saves it as an 8.5 x 11 page.  What am I missing?
Message 6 of 9
vivianisimona
in reply to: yu.becca
I finally discovered a way out!
Instead of printing from the window Model, I "print" after setting (from the layout windows) paper size and drawing scale.
From "Model" I could not be able to print in eps.
I hope I was helpful,
sorry for my English!! Smiley Wink
Message 7 of 9
maxim_k
I do nothing special:
- create Page Setup via Page Setup manager,
- assign this page setup to Layout (or Model)
- in Print dialog select "Save as PostScript"
I have checked via Inkscape - page size ia absolutely the same as in PDF file created from my drawing:
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 9
kecix3c
I am trying to plot the drawing to jpeg. using save as post script. i already set all the printable area and also the paper size. once im done, when i save the file. it doesnt print the priintable area. (see attachment)
is there any solution for this ? im am new in autocad mac.
Message 9 of 9
maxim_k
in reply to: kecix3c
Welcome to the Autodesk Forums!
If the scale of printed output doesn't matter for you, then set Paper orientation to Landscape (because you set printing area as landscape) and check-mark "Fit to paper":
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
