AutoCAD for Mac General Discussion
Active Member
michael
Message 1 of 36 (3,267 Views)
Accepted Solution
AutoCad 2013 LT for Mac
3267 Views, 35 Replies
04-20-2012 11:07 AM
How can I set the default save as to 2004?
i have read and tried the various suggestions from previous posts and seem to be unable to get it to change -
thanks
md
Hi md,
1. Quit AutoCAD.
2. Open Terminal.app
3. To set default format for save to AutoCAD 2004 format - copy this string an paste it to Terminal command prompt:
defaults write "com.autodesk.AutoCAD LT.R19.0.ACADLT-B033.409" "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 24
4. To revert back:
defaults write "com.autodesk.AutoCAD LT.R19.0.ACADLT-B033.409" "HKEY_CURRENT_USER.SOFTWARE.AUTODESK.AUTOCAD LT.R19·0.PROFILES.<<UNNAMED PROFILE>>.GENERAL.DEFAULTFORMATFORSAVE" -int 60
Maxim
*Expert Elite*
maxim_k
Message 2 of 36 (3,255 Views)
Re: AutoCad 2013 LT for Mac
04-20-2012 09:10 PM in reply to: michael
Hi md,
1. Quit AutoCAD.
4. To revert back:
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
xkaila
Message 3 of 36 (3,087 Views)
05-10-2012 03:39 PM in reply to: michael
what would the code be for regular autocad 2013? not LT? i've been searching everywhere for the answer and cannot find it. and what is the code for default file format in 2002?
*Expert Elite*
maxim_k
Message 4 of 36 (3,036 Views)
05-11-2012 08:09 AM in reply to: xkaila
Not a problem. Here are the codes:
1 - AutoCAD R12 DXF
12 - AutoCAD 2000 DWG
13 - AutoCAD 2000 DXF
24 - AutoCAD 2004 DWG
25 - AutoCAD 2004 DXF
36 - AutoCAD 2007 DWG
37 - AutoCAD 2007 DXF
48 - AutoCAD 2010 DWG
49 - AutoCAD 2010 DXF
50 - AutoCAD 2010 DWT
60 - AutoCAD 2013 DWG
61 - AutoCAD 2013 DXF
62 - AutoCAD 2013 DWT
For AutoCAD 2002 use "12" (AutoCAD 2000 DWG)
HTH
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
xkaila
Message 5 of 36 (2,988 Views)
05-15-2012 10:34 AM in reply to: michael
thank you.
but what about the code to enter in terminal? because it is different for the full version of autocad 2013 than lte? and the "set av" "DefaultFormatForSave" does not work i'm afraid.
*Expert Elite*
maxim_k
Message 6 of 36 (2,983 Views)
05-15-2012 12:01 PM in reply to: xkaila
For full version of AutoCAD you don't need to use Terminal, look here:
http://wikihelp.autodesk.com/AutoCAD_for_Mac/enu/Community/Tips_and_Tricks/Drawings/Set_the_Default_...
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
xkaila
Message 7 of 36 (2,981 Views)
05-15-2012 01:24 PM in reply to: maxim_k
Yeah... That's the method that does not work i'm afraid.
but thank you anyway.
*Expert Elite*
maxim_k
Message 8 of 36 (2,958 Views)
05-15-2012 09:08 PM in reply to: xkaila
Why? What AutoCAD do you have? (version, LT or full)
If you have full AutoCAD 2013 - should work!
Maxim
Architect
MARSS
MacACAD | MARSS
Active Member
xkaila
Message 9 of 36 (2,937 Views)
05-16-2012 12:00 PM in reply to: maxim_k
I do have the full version. but the command has changed.
setev is now setvar, which i do, but when i enter "DefaultFormatForSave""24" after it, it says it does not recognize the command in my command line.
*Expert Elite*
maxim_k
Message 10 of 36 (2,932 Views)
05-16-2012 12:23 PM in reply to: michael
setenv is not a System variable as, but AutoLISP function, so you have to include this AutoLISP statement in parentheses as you see in Wiki page
(setenv "DefaultFormatForSave" ...)
Maxim
Architect
MARSS
MacACAD | MARSS
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
