AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2013 installation "incompatible graphics card?
5 REPLIES 5
1020 Views, 5 Replies
Any solution to the above problem please?
Intel GMA X3100:
  Chipset Model:GMA X3100
  Type:Display
  Bus:Built-In
  VRAM (Total):144 MB
  Vendor:Intel (0x8086)
  Device ID:0x2a02
  Revision ID:0x0003
Anton dw
5 REPLIES 5
maxim_k
Welcome to the Autodesk Forums!
Which Mac model do you have?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
maxim_k
I checked just now- it seems you have 13" MacBook (2008 model).
As I know only Mac models from 2009 and later are supported do AutoCAD for Mac (all versions from 2011)
So, unfortunately there is no solution for your Mac model if you want to install AC for Mac on it.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
Hi maxim it is a 4.1 MacBook?
Sent from my iPad
Anton de Wit
Director of Engineering & ICT
Gotel Communications Ltd
Yola
Adamawa State
Nigeria.
9° 18.2929 N 12° 28.4575 E
Email: Anton.dewit@gotelafrica.com
Skype: Coppertronics Engineering Services
Cell: +234 (08185363761) Etesalat
Cell: +234 (07080597632) Airtel
Cell SA : +27 (0) 836531161 MTN
Thanks Maxim , bad luck , what is the option to have Duel O S systems on the Mac OS and PC ? What's the best way to load the sys,s if possible ?
Regards
Sent from my iPad
Anton de Wit
Yola
Adamawa State
Nigeria.
maxim_k
Hi Anton,
It all depends on how much RAM you have on your Mac, if it is below 3 Gb, than I can suggest you to install Windows on Bootcamp partition. You will need to reboot your Mac each time you want to use different OS.
If your Mac has enough RAM, than you can install Windows in virtual machine (use Parallels Desktop or VMWare Fusion), than you will be able to run Mac OS and Windows simultaneously.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
