AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2013 for Mac will not launch
8 REPLIES 8
Message 1 of 9
daccordo
784 Views, 8 Replies
Tried to launch the program and have the AutoCAD Error Report box come up saying, A software problem has caused AutoCAD to close unexpectedly.
Error report contains
crashLog.txt
dmpuserinfo.xml
dumpdata.zip
system_profile.xml
Was working fine after loding both SP1 andn SP2. The last file used did have a jpg. that was converted to a pdf for an underlay.
Any help would be wonderful.
daccordo
8 REPLIES 8
Message 2 of 9
maxim_k
in reply to: daccordo
Hi daccordo,
I think you have to try to reinstall AutoCAD (with deleting AC preferences when you will run Remove AutoCAD application).
Or you can simply try to delete AutoCAD preferences file from ~/Library/Preferences folder,
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 9
daccordo
in reply to: maxim_k
Did all you advised and still no luck.
daccordo
Message 4 of 9
maxim_k
Does it crashes in all cases? When you are trying to launch it from Dock, when you double-click on DWG file in Finder (or use "Open with")?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 9
daccordo
Either way from dock or double clicking on a file. Haven?t tried ?Open with?.
Message 6 of 9
maxim_k
What do you see in System.log in Console app when you are trying to launch
AutoCAD?
Maxim
Maxim
Sent from my iPhone
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 7 of 9
daccordo
Feb 24 08:20:08 domenicos-mbp lmuopen[7413]: Launching: /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/LMU
Feb 24 08:20:14 domenicos-mbp WindowServer[83]: CGXSetDeferredUpdates: Default deferred updates value: 1
Feb 24 08:21:00 domenicos-mbp LMU[7412]: exiting and supressing hooks: 0
Thanks in advance for the help.
daccordo
Message 8 of 9
maxim_k
It appears that something wrong with AutoCAD lisence on your Mac. Try to reset it:
So you need to follow this article:
http://knowledge.autodesk.com/support/autocad-for-mac/troubleshooting/caas/sfdcarticles/sfdcarticles...
or "illustrated" guide here:
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
in order to reset existing license information on your Mac, then you need to activate AutoCAD again with your serial.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 9 of 9
daccordo
I?ll try using the ?illustrated? guide and let you know how it turns out.
I did reinstall after the hard drive was replaced and also updated with SP1 and SP2 as you mentioned a few months ago. All worked well until now.
daccordo
”Boost
