AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2013 for Mac does not run on MacOS 10.6.8 [Snow Leopard]
9 REPLIES 9
Message 1 of 10
kevin.v.thai
3597 Views, 9 Replies
AutoCAD 2013 for Mac does not work at all on my computer, it just hangs on the splash screen; and I need this for class.
Plus, I updated it with SP2 and it still won't run.
https://copy.com/733BZWt6TGsU
Intel Core 2 Duo @ 2.4GHz
8GB 1067MHz DDR3 RAM
NVIDIA GeForce 320M
256 MB VRAM
9 REPLIES 9
Message 2 of 10
maxim_k
in reply to: kevin.v.thai
Welcome to the Autodesk Forums!
Have you managed to launch AutoCAD on your Mac at least one time? Or you can not start it after installation at all?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 3 of 10
kevin.v.thai
in reply to: maxim_k
I've tried starting it up several times, and once after I installed ServicePack 2, but it hangs on the splash screen
Message 4 of 10
maxim_k
Could be an issue with Flexnet license manager.
If you have Adobe software on your Mac you can try this solution:
http://upandready.typepad.com/up_and_ready/2013/02/reset-standalone-licensing-on-the-mac.html
It is about reseting standalone licensing if you restored or migrated with Time Machine backup, but it also could help if you have Adobe software on your Mac.
If this would not help, then post a part from System.log in Console application at the moment when you launch AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 5 of 10
kevin.v.thai
Ah, I do have Adobe CS6. I'll try this then.
Thanks!
Message 6 of 10
kevin.v.thai
Nope, didn't work.
Here's the Syslog narrowed only to Autodesk related items:
[AutoCAD is initiated]
Sun Feb 16 15:59:04 Apple-MacBook-Pro-A1278 \[0x0-0xa70a7\].com.autodesk.AutoCAD[38303] <Notice>: set SkipExisting to true
Sun Feb 16 15:59:04 Apple-MacBook-Pro-A1278 \[0x0-0xa70a7\].com.autodesk.AutoCAD[38303] <Notice>: Materials Configuration Not Found in the Bundle - Skipping
[Unrelated logged stuff goes here]
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: 38346 DAEMONIZE: setting umask 0
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: 38346 DAEMONIZE: session parent exiting
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: exiting and supressing hooks: 0
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38347] <Critical>: 38347 DAEMONIZE: session new session leader
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38347] <Critical>: 38347 DAEMONIZE: tty disconnect parent exiting
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 DAEMONIZE: tty disconnect child
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 DAEMONIZE: closing file descriptors
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 Execing /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/lmuopen
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 with argument: lmuopen
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 with argument: /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/LMU
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: !!!! exec failed with result: -1
[AutoCAD stops responding]
Message 7 of 10
maxim_k
From Console output it is absolutely clear that the problem is in activation (LMU stands for License Manager Utility). If you followed the steps in the link I provided before and did not got positive result, you can also try to create new admin account on your Mac and install and launch AutoCAD from it (at first remove AutoCAD from your current account).
But before this you can also try to disconnect from Internet (unplug cable or turn off WiFi) and launch AutoCAD - do you see the same result?
In general, it appears that you have permissions problem on your Mac and License Manager could not write necessary information to Library folder,
Is it possible that you use your account as root? I don't see user name in System log you provided, it is visible only in "All events" section of Console.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 8 of 10
kevin.v.thai
I'll try it again in offline mode.
My account is an admin account anyway.
Message 9 of 10
kevin.v.thai
I finally figured out the problem.
I usually like to sort my applications in sub-folders based on their use.
However, certain software only works if it's placed in the root of the Applications folder
Message 10 of 10
”Boost
