AutoCAD 2013 for Mac does not work at all on my computer, it just hangs on the splash screen; and I need this for class.
Plus, I updated it with SP2 and it still won't run.
MacOS 10.6.8 [Snow Leopard]
Intel Core 2 Duo @ 2.4GHz
8GB 1067MHz DDR3 RAM
NVIDIA GeForce 320M
256 MB VRAM
Welcome to the Autodesk Forums!
Have you managed to launch AutoCAD on your Mac at least one time? Or you can not start it after installation at all?
Maxim
I've tried starting it up several times, and once after I installed ServicePack 2, but it hangs on the splash screen
Nope, didn't work.
Here's the Syslog narrowed only to Autodesk related items:
[AutoCAD is initiated]
Sun Feb 16 15:59:04 Apple-MacBook-Pro-A1278 \[0x0-0xa70a7\].com.autodesk.AutoCAD[38303] <Notice>: set SkipExisting to true
Sun Feb 16 15:59:04 Apple-MacBook-Pro-A1278 \[0x0-0xa70a7\].com.autodesk.AutoCAD[38303] <Notice>: Materials Configuration Not Found in the Bundle - Skipping
[Unrelated logged stuff goes here]
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: 38346 DAEMONIZE: setting umask 0
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: 38346 DAEMONIZE: session parent exiting
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38346] <Critical>: exiting and supressing hooks: 0
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38347] <Critical>: 38347 DAEMONIZE: session new session leader
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38347] <Critical>: 38347 DAEMONIZE: tty disconnect parent exiting
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 DAEMONIZE: tty disconnect child
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 DAEMONIZE: closing file descriptors
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 Execing /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/lmuopen
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 with argument: lmuopen
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: 38348 with argument: /Applications/Autodesk/Adlm/R5/LMU.app/Contents/MacOS/LMU
Sun Feb 16 15:59:14 Apple-MacBook-Pro-A1278 LMU[38348] <Critical>: !!!! exec failed with result: -1
[AutoCAD stops responding]
I'll try it again in offline mode.
My account is an admin account anyway.
I finally figured out the problem.
I usually like to sort my applications in sub-folders based on their use.
However, certain software only works if it's placed in the root of the Applications folder
