Can Autocad 2013 for Mac works with MAc OSX mavericks?
Hi there,
I upgraded to Maverick, without a second thought on Friday, only to discover it has caused glitches to my AutoCAD. The most obvious one being I now cannot edit a text attribute without it freezing Auto CAD and have to force quit the software. I have uninstalled and re-installed 3 times to no avial, even when not saving my AutoCAD prefernces and having to start from scratch.
I've spoken to Apple Care, which were quite hepful, but have simply bounced it back to Autodesk's court.
I would suggest you don't install MAverick until a new update is provided by Autodesk.
Hope this helps.
Regards
Nigel
Hey Maxim,
There was a service pack that updated AC 2011 to run properly on Mountain Lion. Hoping the same for Mavericks,
Thanks!
@briandbrown wrote:
There was a service pack that updated AC 2011 to run properly on Mountain Lion...
Not really sure about this, because at this page about AC 2011 for Mac System requirements:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15802859&linkID=15839490#section10
you can read:
And the last SP - SP3 was released 2011-Oct-17, but OS X Mountain Lion was released on July 25, 2012 for purchase and download through Apple's Mac App Store.
Maxim
SO what do we do if we have an LT version. to get it to work with mavericks OS
I use Autocad LT 2013 every day and foolishly upgraded to Mavericks without checking for compatibility issues - and found out the hard way.
LT3013 will run intermittently on Mavericks but is not sufficiently stable to get any real work done - too many crashes.
I have downloaded the 30 day evaluation copy of LT2014 and it works great - so far 100% stable. I hope that a fix for the 2013 LT compatibility is released in the next 30 days or I will need to de-install Mavericks and I really don't want to go there.
Does anyone have any alternative suggestions?
John
HI mikebyrnes11,
You have only one option to use AC LT 2013 on Mavericks at the moment.
Please look at nearby topic:
Maxim
HI John,
Maxim
Confirming that AutoCAD for Mac and AutoCAD LT for Mac 2013 Service Pack 2 is now available, which includes support for OS X 10.9 Mavericks.
AutoCAD 2013 for Mac Service Pack 2
AutoCAD LT 2013 for Mac Service Pack 2
i've installed service pack 2 successfiully (I think)
BUT
I get the following version number when I check per the readme
Command: _vernum
_VERNUM = "G.55.M.208" (read only)
NOT G055.M.208
what am i missing?
thanks,
