AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Autocad 2013 compatibility with Mavericks?
88 REPLIES 88
Message 1 of 89
izernet.ada
14980 Views, 88 Replies
Can Autocad 2013 for Mac works with MAc OSX mavericks?
88 REPLIES 88
Message 21 of 89
philip.s
in reply to: adamchr
Sure thing Adam and I'll follow up on this forum thread 🙂
Message 22 of 89
enquires
in reply to: philip.s
Evening all,
Quick update, I've conducted a very brief test on my laptop (Macbook air i5 1.7 Ghz, 4GB), found my trial copy of AutoCAD and installed.
Checked all appears to be working, i.e it opend ok, was able to open and work on drawings, save etc, all ok and appears stable. No suprise there as 2013 I have found on my main iMAC to be very good and nice and stable.
Downloaded and installed Mavericks, now I must stress this is by no means an in-depth test and should not be taken as a "green" light that 2013 works with Mavericks, but opened up AutoCAD, loaded a drawing and played about for a bit, all seems well.
Am now going to leave open for a longer "soak test" to see what happends.
So in short, my non in-depth test has resulted in nothing happening YET.
Please take this will a large dose of caution as the laptop is not my main work station so if it all goes "pear shaped" I've losted nothing.
If anybody else has done something similar would love to hear about it.
Message 23 of 89
mark
Philip,
I unfortunately downloaded Mavericks OS 10.9 and have the same problem as one of the other folks here.  AutoCAD LT 2013 hangs up when you edit a block or attribute and hit OK or enter.  I am currently unable to use AutoCAD on my PowerBook.  We need a fix right away.  Big problem here.
Mark T.
Message 24 of 89
maxim_k
in reply to: mark
I have one "quick" idea, while AutoCAD for Mac developers works on update for AC 2013 in order to make it compatible with new OS X, you can download trial version of AC LT 2014 for Mac, install it and use as long as 30 days. Hope that fix for 2013 will be ready soon.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 25 of 89
in reply to: maxim_k
URGENT HEEEEEEEEEEEEEELP!.......PLEASE
Message 26 of 89
has that latest patch corrected the issues?  ie will it now work on Mavericks?
Message 27 of 89
maxim_k
Which one do you mean by "latest"?
There was only one patch (Service Pack 1 for AC 2013 for Mac) and it couldn't correct the problem, because it was released one year ago - 2012-Oct-11.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 28 of 89
enquires
Got to ask why its taking so long!!!!
AutoDESK did make the statement of wishing to align with Apple OS releases!!!!!!
Message 29 of 89
maxim_k
in reply to: enquires
The statement concerned the release of new releases of AutoCAD.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 30 of 89
pendean
A4M2014 with Apple's latest OS is the implication (and so far, what is being offered).
So it will be A4M2015 for Apple's next itiration.
and so on.
If they want to pick up A4M2013 or lower they will make that statement soon enough. Watch for it if it happens.
Message 31 of 89
wei503
in reply to: pendean
Thanks for your patience!
AutoCAD 2013 for Mac SP2 beta build is available now. This build fixes the compatibility isses on Mavericks as well as some other improvements.
Please see details here:
http://forums.autodesk.com/t5/AutoCAD-for-Mac/AutoCAD-2013-for-Mac-SP2-Beta-is-available/td-p/455998...
Wei
Wei Ma
AutoCAD for Mac QA Manager
Message 32 of 89
I just registered and downloaded the update.
When I try to run it gives me a message that Autocad and SP1 must be installed. I purchased Autocad from the App Store but it seems that this update doesn?t recognize it.
How do I work around this problem?
Michael
Michael Drazin
michael@mdrazin.com
o: 203.989.0546
c: 617.256.4449
Message 33 of 89
maxim_k
in reply to: izernet.ada
Hi Michael,
The Update is for full AutoCAD, not LT that you own.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 34 of 89
mark
All,
There was a suggestion a couple pages back that you could download the free LT 2014 30-day trial, until AutoDesk finishes the Beta test of the fix for LT 2013 versus Mavericks.
FYI:  According to an online chat I just had with an AutoDesk representative, once you download the free trial, at the end of the 30 days you WILL NOT be able to get the upgrade from 2013 to 2014.  You will have to pay for the full version of 2014 and not save the $600!
You would think that AutoDesk would waive this requirement, since they and Apple have caused us all quite a bit of heartburn???
Message 35 of 89
YES. UPDATE DOES NOT WORK ON AUTOCADLT2013.
MAVERICKS MORE THAN 200 NEW FEATURES.
YES, ONE OF THIS IS ''KILLING THE AUTOCADS''!...
Message 36 of 89
mark
in reply to: wei503
No, according to AutoDesk the upgrade from LT 2013 to LT 2014 works.  But if you use the free 30-day trial of LT 2014, after the 30-days goes by you cannot use the upgrade to 2013.  You have to buy the full version of LT 2014.
Message 37 of 89
sarra.cenia
in reply to: wei503
Are there plans to release an update / beta build for Mac LT as well?
Using Autocad LT for Mac 2015 on Yosemite
Message 38 of 89
philip.s
in reply to: mark
Hi Mark,
I would like to confirm that trial usage has NO bearing on the Autodesk upgrade process and policy.
If you have an eligible AutoCAD LT for Mac 2013 license (excludes the AutoCAD LT for Mac app), you would currently be able to upgrade it to AutoCAD LT for Mac 2014 regardless of whether or not you have already installed the 2014 software. As a matter of fact we actually encourage doing so, as it provides a testing opportunity prior to committing with a purchase.
My apologies for the false information that was previously provided to you and please don't hesitate to let me know if I can provide additional clarification!
Message 39 of 89
in reply to: wei503
What sort of timeframe is there likely to be a student version of AC2014 available in?
Cheers
Message 40 of 89
jessica.t
Hi Daryyl,
Welcome to the Discussion Forums!
We have a student version of AutoCAD 2014 available for free on our Education Community website.
All you have to do is register and then begin downloading!
If you have any other questions let us know!
Jessica Thrasher
”Boost
