AutoCAD for Mac General Discussion
Active Member
rick
Message 1 of 5 (563 Views)
AutoCAD 20122 for Mac won't launch after updating to 10.7.3
563 Views, 4 Replies
02-09-2012 09:18 AM
updated today to 10.7.3 and now AutoCAD starts to load for 5 seconds and then dissappears.
Have already tried the Terminal/savedState,etc. fix several times and it doesn't work.
Using a 2.5 Ghz Intel Core i5 iMac w/12 G's ram.
Stuck in the mud.
rick@academyinc.com
New Member
asanbey
Message 2 of 5 (490 Views)
Re: AutoCAD 20122 for Mac won't launch after updating to 10.7.3
02-21-2012 01:49 AM in reply to: rick
Any solution????
Active Member
rick
Message 3 of 5 (477 Views)
02-21-2012 07:04 AM in reply to: rick
After days of back and forth w/AutoCAD tech, we tried:
Uninstall AutoCAD, rename the /Library/Preferences/FLEXnet Publisher folder to something else and resinstall it.
Check out the post below:
http://upandready.typepad.com/up_and_ready/2012/02/alias-design-2012-for-mac-the-case-of-the-symbol-...
In my particular case,the re-installed AutoCAD did not even have a FLEXnet Publisher folder,we had to create one,
and finally got it up and running.This is an issue AutoCAD needs to address.What a pain!
Active Contributor
raumpunkt
Message 4 of 5 (444 Views)
02-23-2012 08:09 AM in reply to: rick
Reinstall did not work. AutoCAD does not launch.
Active Contributor
raumpunkt
Message 5 of 5 (424 Views)
02-25-2012 02:38 AM in reply to: rick
autodesk send me this link and it finally worked:
http://usa.autodesk.com/getdoc/id=TS18406763
