AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
autocad 2012 starting problem
11 REPLIES 11
Message 1 of 12
lab.25
2397 Views, 11 Replies
I have an imac i7, 2 gb of graphics card and lions. I installed AutoCAD 2012 but when i want to launch it, after some second the application is closed and I have this message: the application does not respond , I have tried everything ... Can you help me?
I also installed on another macbook and it works perfectly with lion ..
thank
11 REPLIES 11
Message 2 of 12
in reply to: lab.25
I have your same problem. I tried to install the trial version directly from autodesk site, but it doesn't work on my Imac 27" with Lion. Indeed, on my macbook pro with Lion autocad works well, so I don't know which is the problem.
I hope someone help us.
Bye bye
Message 3 of 12
maxim_k
Please, open Console.app and then try to start AutoCAD. What do you see in system.log at this moment?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 4 of 12
in reply to: maxim_k
I do that and this is the result:
Nov 27 19:11:59 iMac-di-Enrico [0x0-0x1a01a].com.autodesk.AutoCAD[220]: Autoload Feature Installed
Nov 27 19:11:59 iMac-di-Enrico [0x0-0x1a01a].com.autodesk.AutoCAD[220]: Materials Configuration Not Found in the Bundle - Skipping
Nov 27 19:12:01 iMac-di-Enrico AutoCAD[220]: This process is attempting to exclude an item from Time Machine by path without administrator privileges. This is not supported.
Nov 27 19:12:01: --- last message repeated 9 times ---
Nov 27 19:12:01 iMac-di-Enrico FNPLicensingService[263]: Started - This service performs licensing functions on behalf of FLEXnet enabled products.
Nov 27 19:12:01: --- last message repeated 6 times ---
Nov 27 19:12:01 iMac-di-Enrico LMU[264]: 264 DAEMONIZE: setting umask 0
Nov 27 19:12:01 iMac-di-Enrico LMU[264]: 264 DAEMONIZE: session parent exiting
Nov 27 19:12:01 iMac-di-Enrico LMU[264]: exiting and supressing hooks: 0
Nov 27 19:12:01 iMac-di-Enrico LMU[265]: 265 DAEMONIZE: session new session leader
Nov 27 19:12:01 iMac-di-Enrico LMU[265]: 265 DAEMONIZE: tty disconnect parent exiting
Nov 27 19:12:01 iMac-di-Enrico LMU[266]: 266 DAEMONIZE: tty disconnect child
Nov 27 19:12:01 iMac-di-Enrico LMU[266]: 266 DAEMONIZE: closing file descriptors
Nov 27 19:12:01 iMac-di-Enrico LMU[266]: 266 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopen
Nov 27 19:12:01 iMac-di-Enrico LMU[266]: 266 with argument: lmuopen
Nov 27 19:12:01 iMac-di-Enrico LMU[266]: 266 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 27 19:12:01 iMac-di-Enrico lmuopen[266]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 27 19:12:33 iMac-di-Enrico com.apple.launchd.peruser.501[117] ([0x0-0x1a01a].com.autodesk.AutoCAD[220]): Exited with code: 255
Nov 27 19:13:14 iMac-di-Enrico LMU[265]: exiting and supressing hooks: 0
Nov 27 19:13:23 iMac-di-Enrico [0x0-0x1c01c].com.google.Chrome[287]: [1127/191323:INFO:breakpad_mac.mm(82)] Breakpad disabled
Message 5 of 12
maxim_k
Not sure exactly, but if you have some Adobe software on your Mac (where you can not start AutoCAD) - have you tried this solution:
AutoCAD for MAC and Adobe software
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
Message 6 of 12
Oh yeah now it works!! On my macbook I didn't this problem with Adobe software, but now no matter.
Thank you very much for your help.
Bye Bye
Message 7 of 12
lab.25
i had this:
Nov 28 21:49:09 iMac-di-Davide Finder[210]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
Nov 28 21:49:22 iMac-di-Davide installd[676]: Exiting.
Nov 28 21:49:41 iMac-di-Davide com.apple.launchd.peruser.501[194] ([0x0-0x3f03f].com.autodesk.AutoCAD[752]): Exited with code: 255
Nov 28 21:49:47 iMac-di-Davide [0x0-0x42042].com.autodesk.AutoCAD[864]: Autoload Feature Installed
Nov 28 21:49:47 iMac-di-Davide [0x0-0x42042].com.autodesk.AutoCAD[864]: Materials Configuration Not Found in the Bundle - Skipping
Nov 28 21:49:49 iMac-di-Davide LMU[909]: 909 DAEMONIZE: setting umask 0
Nov 28 21:49:49 iMac-di-Davide LMU[909]: 909 DAEMONIZE: session parent exiting
Nov 28 21:49:49 iMac-di-Davide LMU[909]: exiting and supressing hooks: 0
Nov 28 21:49:49 iMac-di-Davide LMU[910]: 910 DAEMONIZE: session new session leader
Nov 28 21:49:49 iMac-di-Davide LMU[910]: 910 DAEMONIZE: tty disconnect parent exiting
Nov 28 21:49:49 iMac-di-Davide LMU[911]: 911 DAEMONIZE: tty disconnect child
Nov 28 21:49:49 iMac-di-Davide LMU[911]: 911 DAEMONIZE: closing file descriptors
Nov 28 21:49:49 iMac-di-Davide LMU[911]: 911 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopen
Nov 28 21:49:49 iMac-di-Davide LMU[911]: 911 with argument: lmuopen
Nov 28 21:49:49 iMac-di-Davide LMU[911]: 911 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 28 21:49:49 iMac-di-Davide lmuopen[911]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 28 21:49:57 iMac-di-Davide Finder[210]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
Nov 28 21:50:12 iMac-di-Davide com.apple.launchd.peruser.501[194] ([0x0-0x42042].com.autodesk.AutoCAD[864]): Exited with code: 255
Nov 28 21:50:22 iMac-di-Davide LMU[815]: exiting and supressing hooks: 0
Nov 28 21:50:44 iMac-di-Davide [0x0-0x45045].com.autodesk.AutoCAD[956]: Autoload Feature Installed
Nov 28 21:50:44 iMac-di-Davide [0x0-0x45045].com.autodesk.AutoCAD[956]: Materials Configuration Not Found in the Bundle - Skipping
Nov 28 21:50:46 iMac-di-Davide LMU[1001]: 1001 DAEMONIZE: setting umask 0
Nov 28 21:50:46 iMac-di-Davide LMU[1001]: 1001 DAEMONIZE: session parent exiting
Nov 28 21:50:46 iMac-di-Davide LMU[1001]: exiting and supressing hooks: 0
Nov 28 21:50:46 iMac-di-Davide LMU[1002]: 1002 DAEMONIZE: session new session leader
Nov 28 21:50:46 iMac-di-Davide LMU[1002]: 1002 DAEMONIZE: tty disconnect parent exiting
Nov 28 21:50:46 iMac-di-Davide LMU[1003]: 1003 DAEMONIZE: tty disconnect child
Nov 28 21:50:46 iMac-di-Davide LMU[1003]: 1003 DAEMONIZE: closing file descriptors
Nov 28 21:50:46 iMac-di-Davide LMU[1003]: 1003 Execing /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/lmuopen
Nov 28 21:50:46 iMac-di-Davide LMU[1003]: 1003 with argument: lmuopen
Nov 28 21:50:46 iMac-di-Davide LMU[1003]: 1003 with argument: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 28 21:50:46 iMac-di-Davide lmuopen[1003]: Launching: /Applications/Autodesk/Adlm/R4/LMU.app/Contents/MacOS/LMU
Nov 28 21:50:54 iMac-di-Davide Finder[210]: CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary.
Nov 28 21:50:55 iMac-di-Davide LMU[910]: exiting and supressing hooks: 0
Nov 28 21:51:09 iMac-di-Davide com.apple.launchd.peruser.501[194] ([0x0-0x45045].com.autodesk.AutoCAD[956]): Exited with code: 255
Nov 28 21:51:51 iMac-di-Davide LMU[1002]: exiting and supressing hooks: 0
Message 8 of 12
lab.25
i tried to looking for FLEXnet Publisher but i don't have in library/preferences....
help me please!
Message 9 of 12
in reply to: lab.25
The folder is in this path: MacintoshHD/Library/Preferences. If it isn't here, I can't help you. I'm sorry.
Bye bye
Message 10 of 12
lab.25
i fix everythings... thanks a lots
byeSmiley Happy
Message 11 of 12
pie_777
in reply to: lab.25
lab.25,
I have the same problem, please can you help me? can you tell me how you solved it? I also haven't the FLEXnet folder...
tanks
P.S. I have AutoCAD 2014 on Macbook Pro 15" Retina with intel i7 and 16Gb RAM
Message 12 of 12
maxim_k
in reply to: pie_777
Welcome to the Autodesk Forums!
@pie_777 wrote:
lab.25,
... I also haven't the FLEXnet folder...
tanks
Are you sure you are looking in right place?
Double check: “FLEXnet Publisher” folder is inside MacintoshHD/Library/Preferences folder, but not in ~/Library/Preferences folder (the Library folder inside your Home folder)
Are you installing AutoCAD on your Mac for the first time?
Haven't you migrated from another Mac with AutoCAD already installed?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
