AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
AutoCAD 2011 Update 1 Crash
0 REPLIES 0
Message 1 of 1
RayK1
417 Views, 0 Replies
I have a user with a Mid 2012 Macbook Pro on 10.7.5 that is trying to install Update 1 for AutoCAD 2011 and when he clicks the first Continue button the installer crashes. Tried clearing caches to no avail. Any ideas?  I have attached the relevant portion of the log below as well as the crash report.
Sep 17 17:01:27 ksup20584mac Installer[393]: @(#)PROGRAM:Install PROJECT:Install-690
Sep 17 17:01:27 ksup20584mac Installer[393]: @(#)PROGRAM:Installer PROJECT:Installer-538
Sep 17 17:01:27 ksup20584mac Installer[393]: Hardware: MacBookPro9,1 @ 2.30 GHz (x 8), 8192 MB RAM
Sep 17 17:01:27 ksup20584mac Installer[393]: Running OS Build: Mac OS X 10.7.5 (11G63b)
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: TMPDIR=/var/folders/bw/84wm8g8j2yjgl691rjq4s09m0000gq/T/
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: SHELL=/bin/bash
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: HOME=/Users/dbrooks1
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: USER=dbrooks1
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: LOGNAME=dbrooks1
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: DISPLAY=/tmp/launch-kZCgkO/org.x:0
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: SSH_AUTH_SOCK=/tmp/launch-NV4Jfa/Listeners
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: Apple_Ubiquity_Message=/tmp/launch-casToQ/Apple_Ubiquity_Message
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: Apple_PubSub_Socket_Render=/tmp/launch-iNDPgd/Render
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: COMMAND_MODE=unix2003
Sep 17 17:01:27 ksup20584mac Installer[393]: Env: __CF_USER_TEXT_ENCODING=0x1F7:0:0
Sep 17 17:01:31 ksup20584mac Installer[396]: @(#)PROGRAM:Install PROJECT:Install-690
Sep 17 17:01:31 Installer[396]: @(#)PROGRAM:Installer PROJECT:Installer-538
Sep 17 17:01:31 Installer[396]: Hardware: MacBookPro9,1 @ 2.30 GHz (x 8), 8192 MB RAM
Sep 17 17:01:31 Installer[396]: Running OS Build: Mac OS X 10.7.5 (11G63b)
Sep 17 17:01:31 Installer[396]: Env: PATH=/usr/bin:/bin:/usr/sbin:/sbin
Sep 17 17:01:31 Installer[396]: Env: TMPDIR=/var/folders/bw/84wm8g8j2yjgl691rjq4s09m0000gq/T/
Sep 17 17:01:31 Installer[396]: Env: SHELL=/bin/bash
Sep 17 17:01:31 Installer[396]: Env: HOME=/Users/dbrooks1
Sep 17 17:01:31 Installer[396]: Env: USER=dbrooks1
Sep 17 17:01:31 Installer[396]: Env: LOGNAME=dbrooks1
Sep 17 17:01:31 Installer[396]: Env: DISPLAY=/tmp/launch-kZCgkO/org.x:0
Sep 17 17:01:31 Installer[396]: Env: SSH_AUTH_SOCK=/tmp/launch-NV4Jfa/Listeners
Sep 17 17:01:31 Installer[396]: Env: Apple_Ubiquity_Message=/tmp/launch-casToQ/Apple_Ubiquity_Message
Sep 17 17:01:31 Installer[396]: Env: Apple_PubSub_Socket_Render=/tmp/launch-iNDPgd/Render
Sep 17 17:01:31 Installer[396]: Env: __CF_USER_TEXT_ENCODING=0x1F7:0:0
Sep 17 17:01:31 Installer[396]: Env: COMMAND_MODE=unix2003
Sep 17 17:01:32 Installer[396]: AutoCAD 2011 for Mac Update Installation Log
Sep 17 17:01:32 Installer[396]: Opened from: /Volumes/E049.H.505.r4.acad.mac.x64.update/AutoCAD2011forMacUpdate1.mpkg
Sep 17 17:01:34 Installer[396]: JS: 10.7.5
Sep 17 17:01:34 Installer[396]: JS: Comparision Result 1
Sep 17 17:01:34 Installer[396]: JS: Snow Leopard or higher with version 10.7.5
Sep 17 17:01:34 Installer[396]: JS: Testing hardware compatibility for AutoCAD
Sep 17 17:01:34 Installer[396]: JS: 0
Sep 17 17:01:34 Installer[396]: JS: returning true because Model supported
0 REPLIES 0
”Boost
