Several commands do not work in the AutoCAD 2011 for mac version. The shortcuts are on the CUI interface, but when you try these shortcuts or type the command, they don't work (message: unknown command).
Example (among others):
_qselect (Quick select)
_drawingrecovery (drawing recovery manager)
Thanks in advance for your help solving this.
Solved by Johneng. Go to Solution.
AutoCAD features that are not yet available in AutoCAD for Mac can be found at the following link. Drawing recovery manager is about 14th on the list
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=15833488&linkID=15839490
Thanks very much for your response.
It is quite unfortunate that these commands are not available yet and that we did no know about it (some of them are important tools). I hope they will be available soon and specially that we will be able to incorporate them in our version somehow.
Thanks again.
I can't seem to find the multiline style window in AutoCAD for Mac 2011. I couldn't see that they were omitted in the list of features not included in the Mac version. Does someone know where they are?
stAte option in the -LAYER I tried looking for this in the menu or command, but I was unsuccessful.
Please help me find this command. Thanks
OK, figured it out. The command isn't built into the software. I had to install Windows on my Mac and then download and install the Windows version of this software. I think not having these commands is a big miss, and I question the wisdom of releasing the product without them.
@xaffier wrote:stAte option in the -LAYER I tried looking for this in the menu or command, but I was unsuccessful.
Hi xaffier,
Layer State option is here:
HTH
Maxim
Thanks for the tip. I have found it but it didn't help about Layer Manager issues.
Hopefully it will be integrated in the 2012 version in March
cheers
@xaffier wrote:Thanks for the tip. I have found it but it didn't help about Layer Manager issues.
cheers
Not sure, what kind of Layer Manager issues did you mean?
About integrating Layer states manager into Layers Palette?
Maxim
Hi xaffier,
OK, I got it.
Unfortunately сurrently there is no such a functionality in the AutoCAD for MAC, only command line version.
Maxim
Hi, does anybody know what command to use in order to perform equivalent to ctrl+tab in widows (shifting through different opened cad files)?
thanks
Hi, You can use "Command+~"
More about Shortcut Keys in AutoCAD for Mac see in my blog
Maxim
I think it is system related, so you can't change it (like Ctrl+Tab on Windows).
@vero_d wrote:but i hate having to use both hands. can i change it? where?
why two hands?
Maxim
John
Can we map the Function keys as they were in the PC version (i.e. F3 toggle snap, F7 toggle grid, F8 toggle ortho)?
Alan
I am having trouble while trying to modify the dim settings,everytime I go into dim/modify and try to change arrows,txt,ofsets e.t.c when I go to save settings autocad hangs.can anyone help?
