I received and installed a patch for my Autocad 2013 for Mac on 2nd Janu 2015. It now will not start up. ANy suggestions please as tomorrow is the first day back after xmas! Thanks
Solved by maxim_k. Go to Solution.
If you installed the last SP3 for AutoCAD 2013 for Mac (AutoCAD2013SP3.dmg), than:
Here is what you can try:
- download trial version of AutoCAD 2015 for Mac - http://www.autodesk.com/products/autocad/free-trial
- install it to your Mac
- run it once (maybe this step is optional, not really sure) and close (quit AutoCAD 2015)
- try to launch AutoCAD 2013, now it should start.
- remove AutoCAD 2015 trial version from your Mac (or you can leave it - as you want).
Maxim
EDIT:
Please, report here if it helped you.
This fix works for pre or post OS X Yosemite.
Now for the interesting part. At the start of this investigation process I filed a case claim with Autodesk. I had everything operation, again, by the time I received a call but did receive a call. The interesting part is I was told 2013 AutoCadLT is not (yet) compatible with OS X Yosemite. The tech was completely baffled how this all worked. Maxim_k saved the day! Thank you!!
Autodesk has finally provided a compatible install for Yosemite
Autocad for MAC 2013 includes the latest Service pack: http://knowledge.autodesk.com/support/autocad-for-mac/downloads/caas/downloads/content/autocad-2013-...
DarrenP
